Still Overheating? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2003, 03:26 PM
New Member
Still Overheating?
ok i got a 77 cadillac coupe deville i took out the big 425 motor with a 350 olds. i just put in new radiater but it still overheats from the overflow tank it gets hot and it be steaming and boiling from the overflow tank? what could it be? do i need a new thermostat or maybe a water pump
Old 10-14-2003, 03:36 PM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
Overheating is caused usually by low air flow. Are you running a fan of some sort, and is there a shroud around the fan? Also, what temp stat are you running? And, how old is the pump you are running?
Old 10-14-2003, 03:42 PM
New Member
yeah the fan is ran off the motor and yes there is a shroud around it, i bought the motor from a salvageyard so still the original water pump i guess? and really dont know the temp
Old 10-14-2003, 03:49 PM
Wrencher's Avatar
try changing the thermostat
Old 10-14-2003, 03:50 PM
Tazz
overheating Caddy
Air flow is important like the dude said. You gotta run a fan shroud and have a good thermostat. And the fan is important too, more blades the better, or the fan may have a thermal clutch too, may not be engaging. What kind of temp are you running? Add a gage to see if there is really a problem or maybe your tank is to small. The overflow tank is there to catch the water as the engine heats up then cool down after you shut it off instead of belching it out on the ground. And like the dude said, how old is the water pump?
Todd
Rat Rods Rule!
Old 10-14-2003, 03:53 PM
dmorris1200's Avatar
doesn't play well with others
Did this problem start after just changing the radiator or did you swap the engine and radiator together and then have this problem?
BUILT FORD TOUGH
Old 10-14-2003, 04:03 PM
New Member
well when i had the old radiater in it would be steaming from the side i think there was a leak some where so i was going to get the water pump thermostat or the radiater so i got the radiater first then all that stuff from the overflow tank happend i would let it run for like 10 minutes or so and get hot
should i go with a 180 unit?
Old 10-14-2003, 04:08 PM
I would definately suggest getting a temp gauge installed. It sounds like you're saying this problem has been happening since swapping engines. Are your belts routed correctly so that your water pump isn't rotating backwards? Did you properly purge the air out of the system? Did you check for good coolant flow? If you are not sure if everything is set up correctly since the swap you could try removing the t-stat and run it without a t-stat just to confirm good flow and direction of coolant flow.
BUILT FORD TOUGH
Old 10-14-2003, 04:10 PM
New Member
whats a t-stat?
Old 10-14-2003, 04:12 PM
Originally posted by LOW CADILLAC
whats a t-stat?
Lazy mans way of typing thermostat.
BUILT FORD TOUGH
Old 10-14-2003, 04:15 PM
New Member
oh ok lol so i just take it out and let it run for a while and pinch the hose to see if its flowing
Old 10-14-2003, 04:22 PM
You check for flow by running it without the radiator cap installed and watching to see if you get good flow through the radiators cores. If not done carefully and correctly it could result in damage to your car and burns to you. If you are that new at this I would suggest finding a helper that can give you a hand guiding you through everything. I will say though most people are well schooled in the basic fundamentals of diagnosing a cooling system before doing major drivetrain modifications. Any pictures of this project? You can post on this site for free.
BUILT FORD TOUGH
Old 10-14-2003, 04:26 PM
New Member
heres 1
Old 10-14-2003, 04:28 PM
New Member
Old 10-14-2003, 04:38 PM
clean looking caddy, just need to lower it so it matches your name....lol
I think your t-stat is opening up, since you're overflowing on the radiator, but it's a cheap and easy fix, and would give you a piece of mind. I would change the pump definately. You don't know how long it's been sitting or what it looks like internally. They aren't too expensive either. Did you flush the motor before doing putting it in? I would flush the motor, change out the t-stat and pump and go from there. AND DEFINATELY GET A TEMP GAUGE! Letting the motor boil over like that can cause a lot of damage, so be very careful.
