still rich? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2010, 03:52 PM
whojohnjones's Avatar
still rich?
got my carb rebuilt at high performance shop and it still it smokes black smoke heavily..he says quadrajet may be too big. 1977 Chevrolet 350
Old 08-11-2010, 04:06 PM
Overdriv's Avatar
You might want to take it to a different shop that knows about carburetors.
Old 08-11-2010, 05:21 PM
could it be high gas pressure?
Old 08-11-2010, 05:33 PM
artsvettes's Avatar
Find someone else to work on your carb.
Old 08-11-2010, 08:03 PM
I'll second and third the need to take it to a different shop. The Q-jet is a good match for almost anything. But a strange carb mounted to a strange engine will have to be adjusted which can be a big effort. Putting a Q jet from a 455 Olds onto a 350 Chevy will take considerable tinkering with jet and metering rod sizes. If there is much of a difference in the cams of the two afore mentioned examples you will also have to deal with the springs used to counterbalance the manifold vacuum through-out the RPM and throttle position range from idle to WOT in order to get the metering events correct for the engine's air flow. Plus you will have to adjust the secondary metering air valve for tip in timing and rate which can be other springs, counterweights or both depending upon model. This isn't trivial pursuit, it can be pretty complicated to do, help is at hand get one or both of these books then study up to get ahead of the curve on knowing these things;
http://www.amazon.com/Rebuild-Modify.../dp/1932494189 or http://www.amazon.com/Rochester-Carb...d_bxgy_b_img_b.
Bogie
Old 08-11-2010, 09:51 PM
when he called sayin he was finished I checked it out and didn't pay for the carb rebuild and he said he could tune it more
Old 01-14-2011, 01:05 AM
I found the problem but forgot to report back. the problem was gas tank pressure is too high. fixed it with fuel pressure regulator
Running rich on 6 cylinders, lean in 2? stroker444 Engine 2 08-08-2010 04:11 PM
modifying that too rich edelbrock 1405 carb? TVR383 Engine 23 12-03-2009 10:19 PM
Rich running Buick Estate cruiser68 Engine 16 02-22-2008 03:56 PM
BG/BC Rich Idle & Idle Air Bleeds/IFR 68NovaSS Engine 3 11-11-2006 12:36 AM
Correction 1-7 & 4-6 rich, Holley solidaxel Engine 11 09-29-2005 10:14 AM
