still smoking - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2006, 08:24 PM
still smoking
my 1988 chevy TBI 350 is still throwing black smoke at WOT. and i replaced the EGR valve and the o2 sensor. what else kan the problem be?
Old 06-25-2006, 10:34 PM
Jmark's Avatar
I'd suggest you take it to a reputable shop and have them check for codes. Throwing money at it changing random parts and hoping to find the problem gets expensive real fast.
Old 06-26-2006, 12:10 AM
u see i pulled the codes out myself and got a o2 sensor problem it said it was running lean and when i replaced the sensor it was broken and all black and i replaced the EGR valve cuz it was clogged and old. now my service engine light isnt on any more and my truck still smokes its still smokes
Old 06-26-2006, 03:27 AM
re:still smoking
possible catalytic converter problem. how many miles on it? could possibly need a valve job, do a leak down test and compression test. mechanical problems of this sort may not set off any codes but may cause your problem.
Old 06-26-2006, 04:34 AM
i put in a motor from a 1992 chevy caprice cop car and i ran that motor (which smoked) in my truck for a while until it over heated and water went into the engine so i took off those heads from the caprice and used the original heads for my truck and i sent those to get reconstructed. but the when i got the cop car it didn't smoke at all i guess it might the sensors on my truck or something. And the truck odometer stoped workin at 163000 miles but i dont think that matters cuz the heads are rebuilt unless its the catalytic converter cuz thats still stock i hope this is enough info. for u thanks
-TONY
Old 06-26-2006, 10:40 AM
sbchevfreak's Avatar
Licenced Automotive Technician
MAP sensor, possibly. As stated, take it to a reputable shop, and have the codes read and the data stream monitored. Also have an exhaust back pressure test done, as this will help verify/rule out a converter problem.
Old 06-26-2006, 11:06 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Just how much black smoke is coming out at WOT? Some may be considered normal. If its leaving enough that you cant see out the back window, well thats not normal.
Steve
Old 06-26-2006, 11:41 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
You are going to have to systematically check all the things related to WOT fuel delivery. O2 sensors do not work at WOT.
Check both fuel pressure readings, check TPS setting at WOT, check MAP sensor. I am betting on fuel pressure. Determine if injectors are correct for application.
Old 06-26-2006, 06:52 PM
the smoke comes out when it goes from 2nd to 3rd or from 3rd to 4th only and if i keep it at WOT the smoke keep on comming out but its not really alot but i would like to find out why that happens. thanks
new engine is smoking potts Engine 7 04-04-2006 03:27 PM
Montana Jumps on No Smoking bandwagon crazygutgut Hotrodders' Lounge 85 04-15-2005 04:39 PM
Okay I thought I blew a ring in the 305 but it's not smoking today stonedchihuahua Engine 7 08-17-2003 08:22 AM
header wrap - smoking? andybird Engine 5 07-08-2003 04:20 AM
SMOKING 350 RONALD JONES Engine 5 05-03-2003 07:12 AM
