Still toying with carbs
I found a qjet, should have it soon, while I am waiting I decided to use a different Carter , I had my old Carb the 9635SA or the 1405 which is the same.
I tried to change out the venturi's and squiter and jets rods to a 389 pontiac it didn't fare so good, the idle was real rough. I found in the carb a passage that's part of the idle circiut blocked, cleaned it out and went back to base Calib. and decided to try it and I had a bog at accel. off idle so I tried the rods out of a 1406 just the rods and WOW, I got a chirp when I released the brake and punched it and no bog even when the secondaries kicked in, just trans shifted hard into third, but WOW. This carb the AFB 9635SA almost performed as good as the AVS does. Last edited by raguza123; 08-15-2012 at 08:17 AM. |
I reassembled it back to base configuration and still had a bog with base I tried just changes the rods and the bog disappeared. The 9635 is a universal carb and was never tuned in for my engine, it's for 302 to 400's but needs to be fine tuned. I always had a bog even with the Edelbrocks, off idle it would hesitate then kick in. I know they say the squirter or moving the accelerator one hole. I seem to find a sweet spot, now to try other things like you said. Last edited by raguza123; 08-15-2012 at 08:35 AM. |
That clogged passage is a bleed, its more common than you think for them to clog. Your rods shouldn't affect idle or just off idle at all.
Bending the accel pump rod can also affect your squirter shot. |
I'm just messing around with it, I was looking at the rods closly and I see wear around the steps, maybe the rods were worn too and cleaning out the carb better might have removed the bog, could it be?
| The Following User Says Thank You to raguza123 For This Useful Post: | ||
lg1969 (08-15-2012) | ||
| carbs | blackchevy3de | Engine | 5 | 04-22-2011 10:54 AM |
| New Carbs? | JeffB | Engine | 7 | 09-30-2010 04:29 PM |
| Carbs | geezer1 | Introduce Yourself | 1 | 06-08-2007 08:50 PM |
| Holley Carbs VS. Edelbrock Carbs. | KeithB123 | Engine | 3 | 01-12-2004 10:42 PM |
