The 650 carb isn't too big for the 350, are you sure it's a double pumper? As far as doing away with the injection, why? Sounds like a step backward. Dan
Backwards indeed
Well originally this was a project for me to experiment with the old intakes,carbs and the entire engine. When I bought the suburban I had a 4 cylinder to drive got close to 30 mpg. Then the timing belt slipped a few teeth and beleive it or not ripped the head off and bent all 16 valves. So stuck driving my gas hog.
Yes i know it's not to big for the engine, I was told it was to big for my stock intake and that wouldn't idle right with all that fuel. I'm positive it's a 650 holley 4 bbl. the double pumper I'm pretty sure of it has these 2 springs one on front and one on back when you push then down the front sparys fuel in front and rear sprays fuel into rear. Not sure if that's what double pumper is but my guess. Also need to add another ? I have fuel pressure regulator with gauge i usually have the gauge around 5.5 or 6 any ideas on what to have it set at? |
archonracing,
Stay below 6psi, check it with the motor hot and cold.
Go to the main bulletinboard page, click on the "Hot Rodding Basics" link, click on the first post by Jon, scroll down to the carbs info articles......... Merry Xmas a little late.....articles to read and save for every part of your Muscle car build.... ................................................ 5,000 lb. Suburban, "can't" get high mpg cause of the weight. Last edited by red65mustang; 01-14-2005 at 03:35 AM. |
If its a stock intake, than you had to have used an adapter plate to install the 650 Holley. as far as it being to big for the stock intake, isnt really the issue. The issue is , is it the RIGHT carb?
The stock intake would be a spread bore (quadrqjet), in my opinion that would be the best carb for the application. they are way more cfm than you NEED , however, due to the spreadbore design, there far more forgiving. As far as a square flange carb goes....on a stone stock 350 that wont be revved past 5000 RPMs... Id use a 570 Holley vac. sec. John |
The Import
My car was a 91 mitsubishi eclipse GSX 2.0LDOHC turbo AWD
I took the head off to discover all 16 bent valves it needs to be rebuilt anyway but i plan to fix it when i have more time. A 4 cyl. isn't my main concern now I want a 60's - mid 70's muscle car with v8. will sell the eclipse for parts though have a few performance parts never been used before for it also. |
I understand,nothing like the sound of a v8 is it? That is why I was driving a ford lightning 60 miles one way to work instead of a 4 banger.And was working on honda,s.
On the honda,s we would just replace the bent valves,and timing belt.That is why I thought I would ask.I thought it might be cheaper for you to repair your import.But if you want a something different I understand.Carl |
