its a 700r4 no matter where the shifter is it wants to go forward. took the converter the pump and the clutches and swapped them to another housing and still have the same problem. im thinking torc converter is locked up.what do you think.
It's not the converter, it is internal to the trans or a linkage problem. If the converter is locked, it will behave like a manual trans put into gear without the clutch - a hard slam that either kills the engine or the car starts moving in the direction of the gear that is selected by the shifter - forward or reverse.
As gear choice is selected in the trans, it can't be in the converter, all the converter does is supply power into the trans, it is the tranny's job to direct it to forward or reverse.
Sounds like a clutch problem to me.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
