Stock 1974 sbc 350 build - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2009, 06:59 AM
stoney 81ta's Avatar
I have a stock 1974 350 motor,would like some advise on size of cam to use on a street motor.Also would be using the stock heads.The car its going into is a 1981 trans am with 2.56 gears.
Old 06-20-2009, 11:53 AM
SSedan64's Avatar
With low compression, 2.56 gears and a heavy car you will need a small cam. Comp 260H, 255DEH, XE256H, XE262H
Old 06-20-2009, 06:41 PM
Thanks,will either of those cams will make a noticable difference from stock.And also will i be able to reuse any parts from my 305 motor thats in the car now,like the intake edelbrock performer,1406 carb and headers.
Old 06-20-2009, 07:00 PM
SSedan64's Avatar
Yes, definite improvement over stock cam. Yes, all those parts will work fine.
Old 06-20-2009, 07:14 PM
Thanks Ssedan
Old 06-20-2009, 09:30 PM
DENCOUCH's Avatar
another story
I changed out the cam, headers, manifold & carb on my 1974 350 in search of more hp. After changing out those parts, the motor was still a turd! When I tromped on the pedal, the only thing that happened was, the exhaust made a louder noise
1974 was the worst year for 350's, the heads had combustion chambers that would swallow a cow, and the pistons were dished enough to be mistaken for an Olympic-sized swimming pool
The second time around, I changed out the heads for Vortec and the pistons were given the ol' heave-ho for a set of flat top. I used a steel shim head gasket as well. Compression increases go a long way to improve that seat of the pants feel, as well as increase gas mileage.
...my two cents (but they are HAPPYTWO CENTS )
Clickie for Vid
Old 06-21-2009, 06:07 AM
Clickie for Vid
Thanks for the advise,your vid of your build sounds nice.Due to budget cant afford new heads at the moment,is there any way to modify the stock heads to flow better.
Old 06-21-2009, 09:10 AM
DENCOUCH's Avatar
Flow better? Sure, I bet there are a half-dozen improvements that one could make to raise the flow numbers.
I was hoping that after reading my post, you would understand that this motor needs a compression increase in the worst way. Making other changes first will only leave you scratching your head and wondering if all the trouble and money spent was worth the effort.
Opinion on 400 SBC Build Up. ezobens Engine 21 11-18-2013 08:49 AM
SBC Motor Build weshova Engine 4 10-21-2008 11:10 AM
how to get max hp and tq out of 350 sbc dustinweaver Introduce Yourself 2 01-28-2006 09:43 PM
Issue: Stock SBC rod reliability; being able to hold forged Speed Pros above 6000 RPM BringBackTheCamaro Engine 10 01-16-2006 12:07 PM
Would like a stronger sbc 350 than stock heads. StingRay69 Engine 6 11-12-2005 04:22 PM
