Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - stock 2 barrel carb and pistons good for a 350 sbc build?
Old 12-16-2012, 12:24 PM
Jkingof956 Jkingof956 is offline
Originally Posted by vinniekq2 View Post
I sure hope it doesnt weigh 3900 pounds?If the car weighs 4,000 pounds with you in it and fuel,you might break into the high 13s if the engine makes 350 HP?
320 HP would be about the same times if the car is 3700 pounds total with driver. The 3.55 gear set will work well though ,if you dont add posi you will melt one tire until the spider gears escape. 2,000 stall speed would work well. Tires will need to be good quality.
will this build be enough to make close to the 350hp? any opinions?
also have a 2,000 hughs stall laying around and a dacco 3,000 but am going with the 2000 stall for the small cam
