Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Stock 340 intake or Edelbrock Performer RPM
Old 10-14-2009, 10:51 AM
454C10 454C10 is offline
it seems like you have enough gear for the little 340.
So I would change to the regular rpm intake. Don't get a rpm airgap, as they don't run well in cold climates. Your carb needs heat under it to run correctly. Just use the exhaust restrictor. Get a square flange intake.
what are the cam specs?
how is your ignition timing setup? initial, total mechanical, how much vacuum advance?
