Stock 340 intake or Edelbrock Performer RPM - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2009, 07:09 AM
daveh's Avatar
Hey guys,
I'm finishing up assembling my engine and I want to get a new intake. It's a mild 340 in my 71 Dodge Challenger, 30 over, purple cam, forged crank, 2.02 1.94 heads, etc.
I have a stock intake. I am running a holley 650 double pumper and I am using the adapter plate on the stock intake for the square bore Holley. I want to get as much as I can out of the engine and don't know if the cost of the Performer RPM would be justified and be a better improvement. I am going with the Performer RPM because I think it will fit with the shaker hood. What do all of you guys think? Thanks for all of your help. Thanks
Dave
Old 10-14-2009, 07:37 AM
The stock intake will make more torque under 3500 rpm.
If the car is heavy (4000 lbs +) and has a low numeric gear (less than 3.00) then you will be better off with the stock intake.
Old 10-14-2009, 08:25 AM
daveh's Avatar
It's a convertible
Old 10-14-2009, 08:31 AM
sounds like it is heavy.
automatic? what gear ratio? (highway gears?)
how does it run now?
how about a 440?
Old 10-14-2009, 09:09 AM
daveh's Avatar
The car runs great but I am changing over to a shaker hood and I'm not certain the hood will shut. It's a Tremec TKO600 5 speed. It a posi 3:27 gear. Weight would be an issue for the intake the stock one is heavy compared to the RPM. Which I like. If it won't give me any gain then I won't do it but even if it's a little I will do it. Thanks again
Old 10-14-2009, 09:51 AM
it seems like you have enough gear for the little 340.
So I would change to the regular rpm intake. Don't get a rpm airgap, as they don't run well in cold climates. Your carb needs heat under it to run correctly. Just use the exhaust restrictor. Get a square flange intake.
what are the cam specs?
how is your ignition timing setup? initial, total mechanical, how much vacuum advance?
Which Edelbrock performer(prm) intake for 350 SBC? eric32 Engine 10 10-20-2010 05:51 PM
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
Edelbrock Performer vs Performer RPM vs Air Gap RPM Regal Beagle Engine 10 02-16-2009 07:07 PM
Stock intake vs. modern Edelbrock petiepye Engine 11 02-14-2005 12:08 PM
Edelbrock Performer 390 vs. RPM Byrdie Engine 5 08-09-2004 07:02 PM
