stock 350 vortec in a camaro cam advice. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2009, 02:43 PM
Hi,i just got a stock 350 vortec to put in my 1981 camaro,i would like to know if i should keep the stock cam or ad a l98 that a have.My car as edelbrock performer rpm with a holley 600 vaccum a th350 with 2500stall and 3.08 gears.
thanks
Old 05-12-2009, 03:07 PM
American Muscle's Avatar
305 Turbo-Fire 240hp
Wha are your intentions for the car?
Old 05-12-2009, 04:54 PM
on the street.
Thanks
my87Z's Avatar
Veteran/Firefighter-Paramedic
is that L98 used or new, i would never install a used camshaft into a motor
Old 05-12-2009, 04:58 PM
Thank you 87
Old 05-12-2009, 05:06 PM
cam is used,so i buy a new one any suggestions without changing the valvespring.
Thanks
Old 05-12-2009, 05:17 PM
my87Z's Avatar
you need to chuck the used L98, and you will need to find out everything you can about the motor, it's deffinatly not "one size fits all" when it comes to purchasing aftermarket parts for a motor, you have to know exactly what you are working with in order to figure out what you can buy to get more #'s
find out what the motor came out of year model etc.
#'s off the block, #'s off the heads
if it has the vortec heads you wont be able to use the regular perf RPM intake, the vortec's require a differnet bolt pattern, but you could sell the one you have and put that toward a new/or used vortec compatable intake
« Gm Hei | Vortec 350 »
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Olds 350 help, 2 dead cylinders & cam lift Q? 360Camaro Engine 35 07-10-2005 02:42 PM
97 Vortec 350 in a 95 Camaro torqjunki Electrical 2 12-10-2004 09:32 AM
350 rebuild advice Curly Engine 1 10-05-2002 07:47 AM
350 chevy: stock cam or 3 quarter cam ? 65roln Engine 8 03-19-2002 11:18 AM
