hi guys, i have a stock 40 ford,an know nothing about gear ratio are rear ends, i'de like to make some long distance rod runs , but the stock rear is geard to low. shouild i change rearends or just the gears ,i'de like to cruse about 65, an still not lose any power in town driving.i'm on a tight buget so a colombian is out.just whats involved in changing rearends,i.e.u=joints, springs,ect. any help will be appreciated.
The problem is, your stock 40 rear uses an enclosed drive shaft. If you go to another rear you will also have to change transmission. Thats 1 of the reasons I changed my complete drive train years ago. If you want to keep the flathead, you can use a newer ford trans even a c-4 auto with adaptors. If you can weld and fabricate, you can go to parallel springs or build brackets and use your original spring with an 8" or 9" ford rear. You could check Hemmings for a different gear set. I don't know whats available. I still have a couple 40 rearends, but think their both 411s, thats probably what you have now. Sorry,I don't have a better answer, if I can be of more help, let me know.
Jack
That '40 Ford rearend is probably a 3.78 : 1 ratio...9 teeth on the pinion gear and 34 teeth on the ring gear. Those numbers are usually stamped on the underside of the banjo. Ford did have a 3.54 : 1 gearset that would be a better highway gear but it won't be easy to find. If you do acquire one, make sure you get the banjo with it. That way all you have to do is switch the banjo/center section.
thanks for the replys, i heard from a fellow who said he though he heard that someone made gears for a stock 40 rearend but he didn't remember who . maybe speedway motors. an he didn't know how they worked. have any of you had experienc with this, thanks
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
