stock 400 SBC crank in a 383 turned .030 on rods - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2006, 07:49 PM
Is this too much to be used in a street strip engine? It is a stock 400 crank turned to fit a 350 block, plus .020 more on the mains and .030 on the rods. What might be the RPM and or HP limits? Thanks
Old 04-15-2006, 08:01 PM
Jmark's Avatar
I recently asked my machinist if my 400 crank could go 40/40 to save it and he said sure, do it all the time. Apparently there is plenty of meat on the 400 crank for major turning.
Mark
Old 04-16-2006, 04:56 AM
BOBCRMAN@aol.com's Avatar
Some of the "good ole boys" claim that the thicker bearing shells on undersized bearings blocks good heat transfer to the rod/main bores.
Personally I have run .030 under bearings on race small blocks with no adverse effects. One with .040 rods. I also have .060 under bearings in inventory. Next undersize is small journal std. and thats been done MANY times..
400 Sbc With 350 Crank Six Inch Rods blown volvo Engine 53 02-17-2006 11:36 AM
.60 over 383 SBC Questions Mustangsaly Engine 8 06-28-2005 01:18 PM
383 Crank Hits Pistons 68NovaSS Engine 17 08-09-2004 03:33 AM
how much will stock rods and crank take? nastynova Engine 7 12-30-2002 06:03 PM
350 rods in a 400 sbc Bandeezee Engine 4 12-11-2002 06:51 PM
