stock 427 td suppercharged advice needed asap - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2010, 08:54 PM
hi,i recantly droped in a 427 tall deck into my 1976 gmc jimmy 4x4 and was wondering if i should drop my suppercharger on it or will i destory the motor, i know the motor has low origanal miles with only 1000km after a rebuild, from what i can tell it is bored 30,uses standar rods and main(and most likey 4 ring pistons), the blower is an old bonalite pm-3 blower(its very old but seems to solid and in good shape) just looking for advice for my build like safe psi and rmp or if im just asking for trouble with the blower, thanks in advance
Old 08-26-2010, 10:06 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Most any motor will tolerate 6 psi or less. Make sure you have enough carburetor and keep the mixture fat until you can dial it in. Also drop back on the ignition timing, then dial it back in a little at a time while looking closely at the plugs.
Ford stroker advice needed BstMech Engine 2 09-17-2009 10:10 PM
supercharger advice needed 50gmcratrod Engine 3 04-13-2009 01:36 AM
opinion needed on a combo, cam advice Dubz Engine 2 02-19-2004 01:29 PM
could use a little advice on this Engine combo I am putting together 427 cui ProStreeter 67 Engine 2 09-07-2003 06:22 PM
Rear End Advice Needed Rick Yocum Transmission - Rearend 1 08-08-2002 04:45 PM
