stock 454+blower=????
Hey I have a gen IV 454 from an 88 chevy one ton that i plan to put in my 56 chevy and I've run accross a 6-71 roots blower that I'm really wantin to put on and the guy I bought it from does a lot of drag racing and such and says that the stock internals (crank, rods, pistons, etc) would handle the blower as long as i dont crank the boost up a whole lot. Is this right? if so, what pulleys should i run (how many teeth? etc) i plan to put a small cam in to give it a little lope n am runnin on a fairly low cost build, any help here is greatly appreciated as I'm new to the supercharger world lol
Ok awesome, thanks for the help
You won't get the lope your looking for with a blower, it calms the idle a lot. I have a custom Lunati solid roller grind with an 8-71 SBC, lots of lift and duration, and no serious lope. Blower cams like a wide lsa, in the 112 - 114 range.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
i knew there was more to it than just bolting it on, I've been a mechanic for about 8 years now, I just never supercharged anything lol electric fans no prob was gonna do that and an electric fuel pump anyways, and power steering isn't much to worry about, I figured I'd leave it off since the car didn't have it from the factory. As far as 2 or 4 bolt mains I'm not really sure, I haven't had the time to tear into the engine yet, but it is going to get a full blown build before i put it in the car, I'm kinda waitin to see how much I'm gonna be in for here on the blower lol and I'm not wantin an all out sounds like it damn near died lope, just enough to tickle some toes lol
I would go with a good set of forged blower pistons, forged crank with a double keyway. If it is a two bolt, I would go with studs. Determine if you want to run a crank hub or balancer. That will determine the blower snout length that you will need. If it is a Weiand intake, they are offset to the rear 1", so you will have to account for that. Just trying to help. All this stuff is still fresh, it wasn't too long ago that I built mine. |
Its all good man I know you weren't meaning it that way lol n ok cool I'll check into all the parts n get some stuff on the way, I'm not sure what intake I'll be using yet, its a BDS blower and I kinda figured from what I've seen and putting 2 and 2 together that as long as it's a 6-71 intake most of the stuff is pretty interchangeable between brands. Could be wrong though wouldn't be the first time. I have the blower I just gotta hunt down an intake a snout and the belt drive system and it'll be ready to go on once i get the rest of the motor situated to handle it
I have been putting gmc blowers on stock chevy engines for 30 years.You will have no problems if you dont push it too hard.I currently have a stock rebuilt(by me) 350 with a 6-71 blower in my 39 chevy coupe.I am running it underdriven and run it on regular pump gas.I am building a 24 T-bucket right now with a stock Targetmaster 350 and a 4-71 blower set up at crank speed.I have put many street miles on this set-up,even pulling a pop-up camper for long road trips. Wer'e not talking Pro-Mod racing here,if you drive sensibly you will get lots of fun with this setup. get it on the road and enjoy it!!!
Sure you can put the blower on a stock engine. However, boost is very addicting. I like having the peace of mind that when I romp on it that it is not going to come apart under my feet.
I think you could get away with 3 lbs of boost, a tad more on occassion with a stock motor but I would go any more than that. There are a few things that you can do on a budget to add more secuity, and some things that you can get by without doing. With a stock crank I would atleast stud it. The double key you could probably do without (if you keep your foot out of it). I wouldn't skimp on the carbs though. Lean conditions on a blower motor equals a time bomb. Don't run the belt too tight, especially on a stock crank. Will snap that sucker off (and the blower snout)Just my thoughts. Just trying to help. Blower are a lot of fun, I love driving mine. Gas mileage sucks though. BTW, I am in no way claiming to be an expert. There are PLENTY of great blower guys here (you know who you are). |
This is my experience...My friend has a 35 foot cigarette style boat with two supercharged 454's. Engines were build by a shop,Mercury Marine blocks,Merlin heads,roller cam etc.GMC style blowers running about 8 psi,dynoed at 610-620 HP each at 5000 rpm. One of the engine got into detonations issues ruining several pistons and the block.........
So he finds a few 454 short blocks used as a standby generator.They have two bolt mains and cast crank with 8-1 forged pistons. Me and him re ring,new bearings,bolt on the Merlin heads,roller cam and GMC blower set up.Put on different pulleys to lower boost to about 6 psi.Figured this engine makes 550 hp at 5000 rpm and ran about as good as the pro built engine still in the boat. This home built engine lasted about 50 hours use,and if you know boats in Great Lakes they can run wide open for as long as you want.Far more severe use than a car engine never being run wide open for more than 12 seconds.The engine never blew but got a lot of blow by from failed rings. |
X2 39 chev, can't do this can't do that, kind of funny , I'm running 8.60's with a 2 bolt main bbc and have run 2 bolt main smallblks as well blown . I agree you have to have some knowledge of whats going on. I don't think I would try much if any boost on pump gas, maybe 91 and definately a water/alky setup cheap and they do the job. blower surge or detroit role or lope what ever you call it, is a lean condition at idle, I no people may disagree but more times than not that is the case.period. I like a little bit sounds tough but stupid hard to stage when u have alot, listen to the big boys no surge and fast idle
| gmc 6-71 diesel blower to 6-71 blower thats usable on a big block chevy | dman16 | Engine | 10 | 08-11-2010 10:46 PM |
| BLOWER MOTOR WITHOUT BLOWER | DOKE | Hotrodders' Lounge | 11 | 08-13-2009 08:08 PM |
| Blower or No Blower, That is the question | S10 Racer | Engine | 4 | 12-16-2007 07:55 PM |
| How much does a stock 55 chevy stock 1955 chevy weigh | tiresmoke55 | Body - Exterior | 4 | 08-24-2007 11:57 AM |
| extracting power form a stock 318 stock cam | satelite413 | Introduce Yourself | 1 | 02-03-2005 11:28 PM |
