Stock 74 Pinto front end - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2007, 08:41 AM
Hi, I have a stock 74 Pinto (Mustang 11) front end in my 39 Plymouth coupe. It is well done and handles nice. The problem is that it "hangs" low under the rails and with the lower control arms straight across with the lower crossmember, it is only 3" off the ground. When I raise it up, (airbags) the fenders are above the wheels and it looks like a "gasser". This is not the look I want. Any ideas as to how I can fix this problem? Thanx
Old 10-21-2007, 04:32 AM
Last journal entry: Brakes
How about some 2" dropped spindles? Everybody sells em.
Old 10-21-2007, 04:45 PM
I have 2" drop spindles installed. The problem with the spindles is that it puts the front end even lower.
Old 10-21-2007, 11:12 PM
Sorry, I thought you meant the gasser look was too high. What exactly don't you like about the front end? What "look" are you going for?
Old 10-25-2007, 07:00 PM
Art Deco's Avatar
i know what you mean. I have a pinto font end on my 37 Plymouth and I have to raise the rear of the car first before I can even get a jack under my frame. I'm using 215/65R15 tires on the front and they just fit. i'm thinking of installing a slightly stiffer spring in the front to compensate for the 440.
Let me know how you make out.
slide out tilt front end STAN HUSTON Body - Exterior 8 11-30-2009 01:11 PM
front end too low mopar 36 Suspension - Brakes - Steering 21 11-19-2008 04:44 AM
frustrating front end! 55shoebox Suspension - Brakes - Steering 7 10-10-2007 11:46 AM
Camaro front end swap help Augusto Suspension - Brakes - Steering 9 09-28-2007 08:17 PM
Front end mock up shows some problems, cut n weld or frame shop? Ripped Body - Exterior 9 11-26-2005 07:03 PM
