Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - stock bbc 454 vortec
Old 08-08-2010, 09:05 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
You want to run the open plane intake then what are the rest of the mods? What rear gears? what transmission? If just adding heads and a moderate cam to it I would use a dual plane intake and plop the 850 carb on it. I don`t know the power band of the dart intake, but if it`s the 3000 rpm and up design then you`ll need to tailor the rear gear and cam to it`s power band.
