Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - stock bbc 454 vortec
Old 08-09-2010, 05:17 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
ok so what you might consider doing is to dump the intake that you have and invest in an rpm intake instead of the ill suited open plenum intake ill suited at least for the street unless you can figure a way to get more cr to use a bigger cam w/a power band that better matches the intake the problem i see is with a mismatched combo we see it all the time guys want to use an intake made for a 240 cam and 10.5:1-plus cr on a 9:1 engine at least you have enough carb
