Stock, BUDGET 400sbc. 58cc heads too small? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2011, 01:57 PM
MrChevyDC3's Avatar
Last journal entry: 1st day out!
Sup Guys.
About to disassemble a stock 400sbc to see exactly what went wrong in it. It's running now, but it has a slight knock and <10psi oil pressure while driving I want to get this thing back together with minimal parts, probably just a head and cam change. This will go in a weekend warrior, street cruising machine. A buddy has a set of World Product S/R 58cc at a VERY nice price. My questions are...
1. Will these heads bring my compression up too high? I'm willing to run premium gas.
2. Cam suggestion? Keep budget in mind. I've also learned that a larger cam with plenty overlap can offset high compression, so....?
3. How bad would it be to keep my stock rods and pistons? If it turns out to be something wrong with them, can/should I just get them fixed and stick with a stock sized replacement?
I appreciate your help with this. I'm looking for a reputable machine shop in the lower Michigan area right now. I want to go thru this once and have a strong, reliable motor when done, and hopefully some change left over to complete my 355/Roots supercharger project!!!
Old 02-11-2011, 02:47 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The main problem w/this engine is going to be in the bottom end. Crank and/or bearings, not the pistons and bores. There's a chance the rods will need to be resized if the rod bearings are what went bad. If that happened, you should put a set of ARP rod bolts in the rods before resizing them.
To use 58cc heads, you'll need to measure the piston dish volume on the pistons in it now, and measure the deck height. Those things along w/the head gasket thickness will determine what the CR will be when all's said and done.
So there's no way to give you an exact "yes" or "no" answer about the heads at this point. If this engine is going to get the blower- the heads are out unless you use some big dished pistons to lower the CR.
Old 02-11-2011, 03:33 PM
MrChevyDC3's Avatar
THanks!!!!
I concur that these heads are not "blower-friendly", so I'm saving that for the 355 that I have out back. I plan to get on that right after I get this 400 spinning. It was suggested that I get new bearings and resize the rods (I believe they are 5.65) at minimum once I take my engine to the shop. I'll definitely look into getting ARP bolts in the rods also. I'm trying to keep shop costs as low as possible. But I WILL do what's necessary to keep this engine spinning for years to come.
I'm wondering, if this engine has the same pistons/ deck height as it came with (out of a '71 Chevy sedan), is there no way to 'guesstimate' those values?
Also, anytime I read up on those World S/R heads, it says for "305ci". Is that to say they're too restrictive for a 400ci? I just don't wanna buy these and have a detonation-prone or choking motor.
Thanks again!!!
Old 02-11-2011, 04:21 PM
ericnova72's Avatar
More for Less Racer
Worlds reference to these heads being for "305's" is two things. That is the application the heads are intended for, thus the 58cc chamber, and the fact that World has moved the valve centerlines a bit to allow a better fit of the 1.94" intake valve and have it not be as shrouded by the small bore of the 305. They will work as good as the ordinary SR on you 400 if you can keep the compression ratio down, they are not a bad head, as good as any "Fuelie/Camel hump" head is.
Just as a rough guess, with the standard undecked block, an .041 composition head gasket, and an estimate of 22cc dish volume for the stock piston it would put you at 9.7-1 compression. If the piston is 18cc it would be 10.1-1. You might search the web and see if you can pin down the dish volume on the stock piston. I believe it is 18cc but don't know for sure, I have heard 22cc also.
The stock 400 rod is 5.565" long.
If you need to lower the compression ratio more you could always grind the chamber larger, a deshrouding of the intake valve side of the chamber for better flow could get you 2-4cc, maybe 6cc if you open it up around the exhaust valve also. Relatively simple job. They just won't fit a 305 as well again if you do grind them.
Old 02-11-2011, 04:31 PM
ericnova72's Avatar
More for Less Racer
I should add the SR's for 305's used to be with the altered valve location, but may not be anymore, I could find no current mention of this fact on World's site. The "special" 305 heads may have only been made back before World Products split from Dart.
Old 02-11-2011, 07:00 PM
1: steam holes will need to be drilled in the heads
2: I measure the dish depth on a stock 400 piston to be .200
3: Add .020 piston down in hole plus .200 dish plus .041 head gasket gives a very unfriendly quench distance for 9.7:1 compression
4: Short rods on the 400 sbc causes more side thrust and many times the bore is gouged out just below the top of the piston travel and needs boring and new pistons.
Old 02-12-2011, 04:16 PM
OLNOLAN's Avatar
Cr
Hey Mr. Chevy, Your CR is gonna be too high for pump gas with about any piston you use with 58cc chamber heads. The following is w/a .030 overbore.
L2467F flat 2 valve relief=11.84
H400P flat 4 valve relief=11.59
L2352F .083 dish=10.53
H601P .135 dish 4 valve relief=10.78
You're gonna need a 72cc chamber head to run it on pump gas, they will put you between 9.21 and 10.17 depending on the piston you choose. I think others here are ball parking 350 CI, CR numbers. This is a 400 4.155 w/.030 overbore x 3.75 stroke. olnolan
Old 02-13-2011, 07:48 AM
OLNOLAN's Avatar
22cc Dish
Originally Posted by F-BIRD'88
A KB168 22cc piston will work fine with a 58cc head. Pretty much anything with a dish is good.
Hey fbird, Even a 22cc dish still puts you at nearly 10:1 w/the small chamber head. Way to much compression to run on todays pump piss on the street.
Each to his own, but 10:1 is too high for a daily driver. olnolan
Old 02-14-2011, 04:58 PM
MrChevyDC3's Avatar
So, in order for me to use the 58cc World S/R's, I definitely MUST buy new pistons? I've read that the vortechs don't like to spin over 5k. I don't plan on revving this thing to the moon, but a 6500 redline or so would be nice. Depending on the shape of my rods (and pistons), I was hoping to only clean up the rods, find some budget heads and a matching cam and get this thing on the road. I already have a Edelbrock RPM air gap, Holley 650 carb, 2800 stall and 3.42 gears w/posi out back. th350 trans. Just wanna roast some hides and let it stand up to a few of these ricers out here now. My buddy wants 250 for the heads, complete. Should I look into buying a vortech setup( heads, intake, machining to get lift past .500) instead??? Thanks for all the advice. Payday is friday, I'll be making a decision by then!
Old 02-14-2011, 05:09 PM
ericnova72's Avatar
More for Less Racer
I would buy them at that price if they don't need rebuilding and make them fit my needs by grinding the chamber larger if necessary. It isn't hard to do, and that way you can dial in the compression ratio.
If you can do a little port work a bowl blend and guide boss slimming would really wake them up.
I guess it would depend on your ability to modify them to your needs.
Old 02-14-2011, 05:44 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Another opinion...
If you want to have a cam that wants to peak at >6000 RPM, the SR's are not what I would use. Nor are the production Vortec's. Neither the Vortec or SR 305 head will be a good match for anything over 5000 RPM on a 400 SBC, given their 170cc intake port volume and the 1.94 x 1.50" valves. Not to mention the problems w/getting the CR down far enough that a cam w/a <5K RPM peak can be used. If I had to use either, it would be the Vortec due to its better combustion chamber shape, etc.
If it were me, I'd be looking real hard at one of the budget aluminum heads bought bare w/the seats cut for 2.02" x 1.60" valves. Aluminum heads can tolerate around 1:1 more compression than an iron head. On your 400 w/64cc chambers, 12cc dished stock pistons, a 0.060" quench, 0.030" overbore, the CR would be around 10.3:1- doable w/Al heads, not so much w/cast iron, at least not w/any cushion to speak of.
Old 02-15-2011, 07:58 AM
MrChevyDC3's Avatar
3 options
So it looks like at this point I can plan to go one of three routes
1. CHEAPEST-- World S/R 58cc head. Highest compression option, and I'll have to get some machining done to them to dial in a better compression ratio. I GUESS I can be satisfied with a 5500 rpm redline Also the machining will help them flow better. But they are assembled complete with ARP studs
2. MID PRICE-- The Vortech setup. Same buddy has asome Vortech heads and an intake for a higher price, but they're stock. I'd have to get them worked over to accomodate lift, and buy some valve covers. But if I'll be "miles ahead" in performance, it may be worth it?? Still 5k redline though???
3. Highest cost--- Keep searching for some better aluminum heads that will have me at my optimum compression and I can tailor my redline accordingly.
Seems like I have some decision making in order. I'm kinda leaning towards getting some work done on the S/R's. While looking for some affordable aluminums.
58cc EQ 305 Heads on low compression 1977 smog 350 ? wade786 Engine 9 12-27-2010 01:57 PM
Stock 302, Small budget, Need horsepower! help! phatso2012 Engine 2 08-29-2010 06:05 PM
Rpm Air Gap Intake Onto A Stock 400sbc jarhead_615 Engine 2 04-20-2010 07:27 AM
can i run a 480 lift cam with 58cc heads Mr. Wormy Engine 2 07-09-2006 10:21 PM
58cc vortec iron heads Leon Weathers Engine 2 12-23-2002 06:36 PM
