Stock cam info - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2005, 10:33 AM
scheetz93's Avatar
5.7 chevy Stock cam info
Hi all can any one tell me the specs on a stock cam for a 93 full-size chevy 5.7?? It is not a roller cam.
also here is a site that sell 1.6 rocker they are narrow body rockers for the center bolt head BUT they are NON-SELF ALINGING
http://www.catpep.com/catproducts/ro...nlessroker.asp
Can i use a non self aligning set of rockers?
Old 04-29-2005, 12:09 AM
If it currently has self-aligning rocker arms, you'll need to use self-aligning 1.6's, & you might need to enlarge the hole where the pushrod passes through the head. The 1.6 puts the pushrod a bit closer to the rocker arm pivot, & it might rub on the side of the hole closest to the pivot.
I don't know the full specs for the '93 truck cam, but I believe the intake duration is 179* @ .050 lift.
Old 04-29-2005, 11:54 AM
GoneNova/406's Avatar
1981-1987 non-roller fullsize cars,s wheel and 4 wheel dr. trucks 180/194 dur.@ .050 378/401 lift they did not list the LCA
1981-1987 non-roller full size cars 2 and 4 wheel dr. trucks 194/204 dur. @ .050" 401/423 lift 104 LCA
TPI Cam recommendation . . . its time. Siggy_Freud Engine 2 02-19-2005 06:43 PM
Stock Cam Specs tc33 Engine 3 01-13-2005 09:02 PM
Stock 350 with bigger cam runs ****ty! help MotormanEN Hotrodding Basics 4 11-02-2004 09:10 AM
stock springs with bigger cam camino_man Engine 11 06-26-2004 04:35 PM
350 chevy: stock cam or 3 quarter cam ? 65roln Engine 8 03-19-2002 11:18 AM
