-   -   stock Chevy 1956 rearend gears (http://www.hotrodders.com/forum/stock-chevy-1956-rearend-gears-224436.html)
db flyer 09-27-2012 01:57 PM
I have a stock 56 chev. with th350 trans. and 3.36 gears in rearend. I want to
go with a higher ratio. I have heard that a 3.23 or 3.08 3rd member would fit in my stock rearend housing? Any thoughts or suggestions if these would fit, and where to start looking for one. Craigslist?
cobalt327 09-27-2012 02:12 PM
Some info that may help you w/locating/ID'ing a different rear end is here. I'm not sure the factory had a 3:23 ratio then. But IMHO a 3:23 ratio will not be enough of a difference to bother with, 3000 rpm would become 2884 rpm by going to the 3:23.
Good luck.
db flyer 09-27-2012 02:21 PM
Ya, not much diff. with only 120 rpm lower
big gear head 09-27-2012 02:40 PM
Any '55 to '64 full size Chevy or '55 to '62 Corvette chunk will fit in your housing. The '62 to '64 Chevy II had a smaller differential.
db flyer 09-27-2012 03:42 PM
Thanks for the info on 55-64 full size 3rd member fitting in my 56 housing.
Do you have an idea of the highest gear ratio that may be avail? Thanks
vinniekq2 09-27-2012 04:45 PM
Have you considered taller tires? or at least borrow a set to see if the gear change makes you happy.Back when I was driving with 5.13s I swapped out L-60-15s for L-78_15s,so I could drive from Vancouver BC,to race at Bremerton.
wish I had overdrive,,,it was a long hall at 3700 rpm
db flyer 09-27-2012 05:06 PM
I`m going to try taller tires and see what that does. I have 215.70r15 on and will try 235.75r15 . Wonder what gear ratio change that would be eqivelent to from my 3.36 rear gears .
vinniekq2 09-27-2012 05:33 PM
215/70s are about 27 1/2 tall 235 are over 29,so I bet you will notice,,Note your speedo will not show the new faster speed that you will be going
cobalt327 09-27-2012 07:48 PM
Look here for a suitable calculator.
Highball 10-03-2012 04:15 PM
I can conform that Chevrolet had that ratio in 1956. I was a GM Tech and all I recall were 3:55 and up to 4:11 with a special order 4"56 ratio. In '58 I stared seeing a few 3:42's and then in '60 a few 3:08's. I'm using 3:08's right now in a T-5 setup behind a really warmed up 216 inline six and am happy with the outcome. I use a 30" high tire.
Normbc9
db flyer 10-03-2012 10:31 PM
thanks for your reply, I put on 235/75r15 tires, and will be seeing what that does to my gear ratio. Cobalt sent me a calculator site, and it seems like according to the calculator I will be running around a 3.07 rear ratio.
