Stock column shifter into B&M megashifter - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2002, 09:48 AM
MuscleBlock81's Avatar
NEED 4 SPEED!
Question Stock column shifter into B&M megashifter
Hey, so i picked up this Megashifter from B and M the other day, i own an 81 el camino and i was wondering just what work i'm looking at doing to conver it... i'm welding in a base to bolt the shifter to on my floor and i know i need a hole for the cable, but i don't know much else about how tight to bolt the new lever onto the transmission (its a 3 speed and i only got a 305cid engine for right now) but what really concerns me is the column, i would like to know how to lock it up so i won;t have any interfeerance with it. thanks much,
Bryan <img src="graemlins/mwink.gif" border="0" alt="[mwink]" />
Old 09-11-2002, 11:00 PM
aka Duke of URL
Post
[quote]...but what really concerns me is the column, i would like to know how to lock it up so i won;t have any interfeerance with it.<hr></blockquote>
I would go to a salvage yard and find the steering column out of a floor shift car. At least the replacement collar to remove the shift lever and then remove the shift tube and levers from the column.
But I guess it would be a good anti-theft deterrent as it will give you a little extra time to catch the perp while he is trying to figure out which shift lever to use...
Old 09-11-2002, 11:32 PM
dinger's Avatar
Post
Does this shifter come with the neutral safety switch? I converted a stocker for a friend in a 70 el camino, had to take the stock switch apart and switch the parts aroound to make everything work correctly. a mild headache but doable.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
