Stock Crank/Rods...how much HP too much? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2012, 04:18 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
What is a safe power level for GM factory crank and rods in a Gen1 SBC? I am looking at around 400HP when all is said and done.
Old 03-05-2012, 04:28 PM
delawarebill's Avatar
400 hp
u'll be fine... i'm gussing u have a 2 bolt mains ??? i've never had mine dyno'd but the way it put together i'd say 300+ in my motor..
Old 03-05-2012, 05:04 PM
I figure 400HP is OK, but not much more over. The block is a 4 bolt main.
Old 03-05-2012, 05:48 PM
4 bolt mains....
knock yourself out... a friend had the same motor but really worked with blower... dyno'd 750hp... so 400hp will be no problem.
351 Windsor: minimum 350+/350+ with stock crank,rods and heads? BB72R-Yes Engine 5 07-20-2010 09:18 PM
5.7 in. rods with stock 400 crank? Warrant Engine 6 11-03-2006 08:37 PM
stock 400 SBC crank in a 383 turned .030 on rods flyin99 Engine 2 04-16-2006 04:56 AM
stock crank and rods nova33 Engine 2 08-21-2003 10:35 PM
how much will stock rods and crank take? nastynova Engine 7 12-30-2002 06:03 PM
