Stock Cylinder Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2002, 08:38 PM
stfinney's Avatar
Post Stock Cylinder Heads
I have a question for all you HotRod freaks like me. I have a 1980 350 SBC motor with stock heads, a Weiand Aluminum Intake and a 600cfm Edelbrock Carb. I recently changed the cam to a Comp. 4x4 Xtreme Cam with a 250/258 duration and a .432/.453 lift and new Comp. Cams Valve Springs to match with a .500 lift max. Also new pushrods were installed. With the stock heads I was think of installing a .015 thickness steel shim head gasket to raise compression some and maybe mill the heads some too. Do you think that is a good thing to do to help raise compression? I think it has around 8.3 compression now, but not sure. Any help would greatly be appreciated! Thanks!
Old 10-27-2002, 10:09 PM
E.T. divided by $ spent= Speed
Post
I'm going to run .015 head gaskets and my heads are resurfaced to .010.I calculated 8.6:1 w/ 76cc heads,12cc pistons,025 deck hieght.Prett much your cam don't really need much more compression than you allready have,you might gain a couple lb/ft of torque and 1 or 2 clydesdales.I'd stick the gasket in and forget the milling unless they need it.
Old 10-27-2002, 10:13 PM
Post
Oh yea,go to www.kb-silvolite.com they have a cool compression calculator.
