Stock deck clearance of a 454. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2011, 09:20 PM
im trying to figure out my deck clearance so i can figure my compression ratio out.. does anyone know the stock deck clearance of a 454
thanks
Old 02-14-2011, 09:58 PM
68NovaSS's Avatar
Wiki Edits: 9
Stock 454 stroke is 4", block deck height is 9.8" (true deck is 9.780), rods are 6.135. Find out the piston compression height you'll have it. Half the stroke, rod length, compression distance from the deck height.
Old 02-14-2011, 09:59 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You have to actually measure it- who knows if or how many times the block may have been milled.
It can be done w/nothing more sophisticated than a straight edge and feeler gauges.
Old 02-14-2011, 10:31 PM
68NovaSS's Avatar
Wiki Edits: 9
My post was assuming the motor was assembled and presumed stock. Figured if it was apart, the OP would know to measure it.
Old 02-14-2011, 11:00 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you're looking for a "how far is the piston down the hole" figure to calculate an estimated CR with, use 0.020"-0.025" for a stock unmilled block and a stock compression height piston.
What is the standard deck clearance on a SBC? Silver Surfer Hotrodding Basics 4 01-08-2011 05:44 AM
steel shim gaskets / piston to deck clearance 396 fire_hawk108 Engine 2 07-15-2008 04:28 PM
Question about measuring deck clearance v8hed Engine 3 06-15-2008 04:37 PM
Piston to deck clearance, and compression BourgD Engine 24 05-13-2008 06:36 AM
Deck Clearance-SBC 350 Mr. Goodwrench Motor? acr Engine 7 04-20-2005 04:11 PM
