Stock ECM + 4 pin HEI.. is it possible? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
  #16 (permalink)
Old 01-30-2012, 04:24 PM
EagleMark's Avatar
GearHead-EFI.com
It's really not funny per say, it's a fact. I do a lot of offroaders and use the knock senor to tune an engine, then disable it. But when they whack the frame on a rock while crawling get a knock count, reduce spark and interferes with ther low RPM crawling.
GM test procedure for testing knock sensor is to have scan tool hooked up and car running and hit side of block with hammer...
And yes open headers can cause enough noise to set knock sensor.
  #17 (permalink)
Old 01-30-2012, 05:00 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
I test the knock sensors using a timing light while tapping the exhaust manifold with a light hammer, I love seeing how it retards the timing, seems unbelievable that the combustion pinging could make such loud and potent vibrations.
I have had customeres complaining of low engine power and the cause has been something loose, like a bracket or engine mount triggering the knock sensor.
Recent Modern Electronic Engines posts with photos
How can i tell if i have a stock tbi cam? 94-chevy-koke Engine 0 02-20-2011 05:55 PM
How much does a stock 55 chevy stock 1955 chevy weigh tiresmoke55 Body - Exterior 4 08-24-2007 11:57 AM
extracting power form a stock 318 stock cam satelite413 Introduce Yourself 1 02-03-2005 11:28 PM
looking for more HP in a stock 94 454 jw4413 Engine 5 12-07-2004 08:28 PM
stock 40 cajunone99 Transmission - Rearend 9 01-02-2003 05:43 PM
