Stock, electric fuel pumps: - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 03-12-2012, 09:28 AM
Banned User
What is your opinion on how long a stock (gm) electric in-tank fuel pump can/should last?
This is with TBI.
Old 03-12-2012, 09:32 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Does it have a Fuel Filter (many new Vehicles don't)-if it does, has it been changed regularly? If it has, my guess would be 80-100,000 mies, but there are many people who have gotten over 150,000-
I change mine at 100,000, good or not-my wife was stranded once (about 130 miles from Home)-it's not worth the pain!
Old 03-12-2012, 09:36 AM
Banned User
The thing is, it's in-tank so it probably has one of those sock filters but being in-tank i've never changed it .
The system has an in-line filter which i've changed but that doesn't do the pump any good since it's after the pump?
P.S. The pump has over 307K miles on it, and is original to the car which is why i'm so concerned about it.
Old 03-12-2012, 10:00 AM
johnnyg's Avatar
hold my beer and watch this!
I have had to change two in my vehicles. 86 GMC van 305 V8 mechanical fuel pump 160,000 miles. And 92 Cutlass Supreme 3.1 V6 electric in tank fuel pump 190,000 miles.
Old 03-14-2012, 10:55 PM
the TBI pumps hardly ever fail. i have seen some of them with over 500,000 miles on them. they are good little pumps.
gm MPI pumps from 96 up, those only seem to last 100,000 to 150,000 miles.
the only filter the pump has and needs is inside the tank, that why many of the vehicles don't have a filter after the pump. the only reason it had a filter after the pump was to protect the injectors if the pump began to fail and spread debris in the system.
Old 03-15-2012, 09:55 AM
Banned User
So do you feel the TBI pumps can last really long is due to the relatively low (as compared to MPI) pressure requirement?
The car runs very well, but i'm concerned that its maybe not at top dependability and would consider changing the pump as a preventative maintenance measure.
Have you worked as a technician?
P.S. this is a 90 cavalier.
Old 03-21-2012, 09:44 AM
sbchevfreak's Avatar
Licenced Automotive Technician
Unfortunately, this is not entirely correct. That "sock" is not sufficient to clean all the particulate from the fuel, which, while small enough to pass through the pump, can clog and damage injectors, So the GM will have an external fuel filter to catch this. This is what kills pumps. They do not like a bunch of backpressure. If the external filter is restricted, it makes the pump work harder, which generates heat, which, over time, kills the pump. Change the external filter every 12,000 miles or so, and that little tbi pump will last for years.
Old 03-28-2012, 12:12 PM
EagleMark's Avatar
GearHead-EFI.com
I'd have to agree that TBI in tank pumps last a long time! Mine has 150K on it and no issues, but I also never run below 1/4 tank to keep pump in fluid.
The one's I have seen that do fail without humans doing something to make them fail have been from the 'Sock" filter mounted on bottom of pump. The sock starts to disenagrate letting not only dirt and debree through but also the fibers from the sock!
Although the sock is enough to keep debree from hurting the pump I don't ever recall a vehicle without a fuel filter? The injectors need a much finer cleaning and EFI filters are metal because of pressure but also a lower micron filter spec then a carb filter.
This is more previlent on newer cars with plastic tanks that flex a little when full to empty. You'll slao notice on these non steel tanks that fuel pump assembly is spring loaded to push fuel pump to bottom of tank. It is a great design but the movment helps desinagrate the sock. Newer socks of any quality are better material for flex then older ones I have seen.
These newer pumps are also great for conversions as they have a built in baffle tank. Return fuel is dumped in bucket which is part of the assembly to avoid tank slush when low and the need for baffles in tank.
There's a great writup on how to install these newer bucket type in tank fuel pumps I'm sure the HotRodders will like at:
http://www.gearhead-efi.com/gm-ecm-p...onversion.html
Old 03-29-2012, 05:14 PM
This is true, but newer pump modules have a "dual" sock setup, with an external to the unit sock, as well as one inside the module. Unfortuately, the manufacturers seem tho think the modules are worth 8-10 times what the pump costs. Case in point, I did a pump "repair" on a 2000 Town & Country. The module was $700. The pump and o ring kit - $80. 10 minutes to disassemble the module, and put in just the pump, o rings and strainers, saved my customer $680.
Recent Modern Electronic Engines posts with photos
Electric Fuel Pumps JAMES MEDLEY Engine 2 08-24-2009 09:21 PM
Question on electric fuel pumps and fuel cells. eric32 Hotrodding Basics 14 05-11-2009 08:53 PM
Electric Fuel Pumps Corvair John General Rodding Tech 4 05-17-2007 12:00 AM
Electric Fuel Pumps clsscsb Engine 3 03-16-2004 09:21 AM
electric fuel pumps street rodder 1937 Engine 5 09-21-2003 07:44 AM
