Stock Eliminator "Cheater" Cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2011, 03:26 PM
Trying to find out the cam card specifications for a Cam Dynamics, "Cheater" camshaft for NHRA Stock Eliminator. My power plant is a 1970 Chrysler 340 small block. Please advise. I'd even enjoy having an old cam card spec sheet if available.
Best regards,
Tom
Old 07-10-2011, 06:52 PM
F-BIRD'88's Avatar
Yada Yada Yada
Call Crane Cams.. Get all the numbers stamped on the end of the cam.
They will need these ID numbers
Mic the major and minor diameters of 1 intake and 1 exhaust cam lobe.
The difference is the cam lobe lift.
A good local engine building shop like Oddy's or Jan-Cen, there may have a
"Cam Doctor" cam measurement tool that will measure the cam and generate a cam card with all the valve timing specs.
You'll have to call around.
Class legal "Stock Eliminator" cams are supposed to have "stock" valve lift.
But the duration could be anywhere from 230@.050" to 270@.050"
The LSA is usually tight (102 to 108deg)
"stock" 340 LA mopar cams are like .430" in .450" ex
Some of these stock eliminator cams are custom one off grinds.
If you are not going stock eliminator class drag racing with your car, there are better more powerful cams. If your cam is worn at all don;t bother reusing it.
Old 12-08-2011, 04:05 PM
stock eliminator cam card specs
Got the cam card from Crane. Advertised is .462.473, overlap 118, 108 cl. The .o50 spec is .308/.315, 244/250, max lift at 104 atdc/114 btdc. MP part numbers were P4007275 and P4349243. Superceded p/n, centerline changed to 104.
Old 12-08-2011, 06:34 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Not saying this cam is one, but there have been cam lobe profile/valve spring combos that allowed "controlled" valve loft to occur. This is where the lifter would be purposely allowed to loft off the top of the cam lobe, then it would land back on the closing flank. Tricky to get right, needless to say.
Old 12-08-2011, 06:35 PM
That doesn't sound too radical to me. I was expecting it to have more duration. I know that the top Stock Eliminator guys are very hard on valvetrain parts.
Old 12-15-2011, 12:08 PM
If anyone has ***************
Last edited by 68NovaSS; 12-15-2011 at 02:53 PM. Reason: Classified ad. Please use the Hotrodders Classifieds for classified ads.
Old 12-15-2011, 02:29 PM
engineczar's Avatar
I'll let you know. I have a few different grinds in the shop but I don't think any are Cam Dynamics. Most are Lunati. They're for 68-71 not the 72-73 low compression motor.
BSE Racing Engines
checking and "tuning" a stock 70s chevy HEI Torque454 Engine 5 07-04-2011 10:31 PM
nitrous spray bar "stock" slow'n'steady Engine 8 08-14-2008 03:43 PM
Mounting a 29 Ford pickup bed on the "Stock Frame"??? Dilbert Hotrodding Basics 5 05-26-2008 06:09 PM
Covering stock "plastic" door panels with "vinyl" csilva84 Interior 1 10-05-2007 06:30 PM
