Stock Forged crank in sbc 350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2009, 11:03 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
I was at my machinist the other day hanging out and having some lunch and he told me during the week he rebuilt a roller vortec 350 block out of 3/4 work van that had a forged crank in it. He didn't run any numbers on the crank but he said that there were no casting marks on and of the counter weights were usually on a cast crank you can see the casting marks. Did GM ever produce stock blocks with forged cranks in them? Thanks
Old 12-26-2009, 11:35 PM
zildjian, I've read that some 350's came from the factory with forged cranks, but I don't know what's supposed to be in the newer engines.
Old 12-27-2009, 11:53 AM
Listen and Learn
Wiki Edits: 7
are they the gen I motors? Anyone got a casting number or was there a specific block or vehicle they came in? Thanks
Old 12-27-2009, 11:56 AM
automotive breath's Avatar
Gen I heavy duty trucks and busses came with forged cranks
Old 12-27-2009, 12:08 PM
Listen and Learn
Wiki Edits: 7
any specific years?
Old 12-27-2009, 12:17 PM
1969 - 1986 I believe
Old 12-31-2009, 11:02 AM
Listen and Learn
Wiki Edits: 7
I bought a book a while back titled Chevrolet Small-Block V-8 ID Guide by Pierre Lafontaine. In it there are two forged 350ci cranks. Both are large journal.
1969-1985 cast number is 39411182 2pc rear main
1986-on cast number is 14088532 1pc rear main
Hope this helps anyone else looking for these.
Old 12-31-2009, 12:31 PM
302 Z28's Avatar
When I worked at the local Chevy dealer we would look for engine jobs in any truck over 3/4 ton for forged cranks. Most were warranty and if a new engine was required we usually go to pick what we wanted after the factory guy cleared it. It was some time later the factory guy started breaking the parts after he OK'd it.
Vince
Old 12-31-2009, 09:37 PM
BOBCRMAN@aol.com's Avatar
Vortec 350 steel cranks are quite rare. Only produced in nineties HD trucks & vans.
These are one piece rear main seal cranks. Balanced differently than earlier steel cranks. Crank throws are also different appearance.
I have seen only two over the years.
Old 12-31-2009, 09:58 PM
302 Z28's Avatar
Early forged steel cranks are still around all over the place. When I'm driving around I see old Chevy dump trucks or 1 ton Chevy trucks abandoned in peoples yards and I just wonder if the engine in them has a steel crank.
Vince
Old 01-01-2010, 12:29 PM
Listen and Learn
Wiki Edits: 7
Vince
ill tell you that you will be seeing me climbing under those pretty soon trying to pull the cranks out
Old 01-01-2010, 03:15 PM
Sorry, edited last post. Going to post parts in classified. Newbie mistake.
Cory
Old 03-03-2011, 02:29 PM
i have an 82 305 cid engine does anyone know if that has a forged crank cause i think it has the same stroke as the 350
Old 03-03-2011, 03:41 PM
ericnova72's Avatar
More for Less Racer
No 305 was ever made with a forged crank.
Old 03-03-2011, 05:29 PM
Did the 350's come with forged 2 bolt or only 4 bolt
stock CR and piston dish for SBC 350? brian12c Engine 1 02-15-2007 05:31 PM
stock 400 SBC crank in a 383 flyin99 Engine 2 01-21-2006 06:59 PM
Issue: Stock SBC rod reliability; being able to hold forged Speed Pros above 6000 RPM BringBackTheCamaro Engine 10 01-16-2006 11:07 AM
Would like a stronger sbc 350 than stock heads. StingRay69 Engine 6 11-12-2005 03:22 PM
SBC 350 Crank Balancer Problems bjam2 Engine 8 05-04-2004 07:36 PM
