stock GM vs. aftermarket posi - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2005, 02:40 PM
red_rider52's Avatar
DriveItLikeItsSupostToBeD riven
Hey guys I was wondering if aftermarket posi like Auburn or Eaton preform a lot better than Stock GM posi, i'm just looking for a posi to hook up or spin both tires.
Thanks
Old 02-27-2005, 12:14 AM
abstruse dutch uncle
If I'm not mistaken, GM doesn't make their own limited slip unit. The have used Dana, Auburn, Eaton, and others. Eaton is a rebuildable clutch type, Auburn is a non-rebuildable cone type, and I don't know about Dana or others.
Old 02-27-2005, 10:13 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I've used eaton and auburn limited slip units. they both work well
The one I am looking at is a clutch type and looks to be a spring that looks like an S shape
Old 02-27-2005, 07:09 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
I think his (unanswered) question is: Do aftermarket limited slip units such as Auburn and Eatons perform better than stock GM limited slips.
To which I can only reply: I haven't seen a GM car equiped with a factory limited slip that didn't turn both tires, unless it was well used and the clutches were worn out.
Old 02-27-2005, 09:18 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
The answer was: GM does not manufacture their own limited slip differentials, they use other manufacturers units, and have done so for many years now.
Old 02-28-2005, 04:51 PM
Ghetto Jet's Avatar
it's good to know, but that doesn't really answer his question.
Does the same quality go into the factory installed GM units as the aftermarket Auburns/Eatons ect? That is the question
Old 02-28-2005, 05:50 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
no the actual question was :
"Hey guys I was wondering if aftermarket posi like Auburn or Eaton preform a lot better than Stock GM posi"
the answer is 'yes' they perform as well as the OE posi units. I believe both brands are stronger
Big Block vs Small Block Chevy bigjoedo Engine 82 05-03-2010 03:36 PM
stock vs. aftermarket intake darom Engine 13 11-03-2004 07:35 PM
max lift for stock gm 882 heads 87 monte ss Engine 16 10-13-2004 02:48 PM
GM Front Diff. Reliability For Full Time Use. M&M CUSTOM Transmission - Rearend 4 10-31-2003 05:36 PM
97 GM posi question chevypu Transmission - Rearend 0 06-18-2002 04:43 AM
