Doc here,
Do these help? ![]() ![]() As far as learning Wire harness procedures.. First READ the Trouble shooting chapter in the beginning of the electrical section of your Chiltons.. until you understand it.. Then if you have more questions..were all here glad to help! Doc
Aftermarket Solutions Electronic & Electrical Innovations |
Doc here,
Yes, in fact you do..Carbed or not... Al GM vehicles manufactured after 1980 have a computer to control Engine functions, and some (later models) control lighting and body control functions... It should be located in the right kick panel Or Behind the glove box.. Doc
Doc here,
You need to convert to a pre 80's HEI or Aftermarket HEI..(see above diagram under distributer connector connections from the computer) The pre 80 HEI will not require this plug to operate, just power and tach.. You will also have to provide a switch or bypass For The TCC (Torque Converter Control, if it's an automatic) The rest can go away.. HOWEVER, I highly suggest you go to a 4 ME Carb..(no computer connections) as The 4 EME won't run exactly right...It will run OK, but not optimum..and at fuel prices today....well you get the idea.. I'm hoping you don't need to pass a smog inspection for your state...cuz...you won't...you need to comply with Federal standards for 1985 as far as equipment in visual inspection, and emissions standards on the sniffer..Of course this is mute if your state dosn't require it.. Doc
Aftermarket Solutions Electronic & Electrical Innovations Last edited by docvette; 11-04-2005 at 02:54 AM. |
Doc Here,
Doc
| after market or stock rods? | jesse01 | Engine | 10 | 03-12-2005 06:04 PM |
| Stock rod bolt ? | bowtieorbust | Engine | 1 | 11-09-2004 12:08 PM |
| stock vs. aftermarket intake | darom | Engine | 13 | 11-03-2004 07:35 PM |
| sleeper cars | antirice | Hotrodders' Lounge | 25 | 08-01-2004 08:29 AM |
| 400 Compression, Stock Pistons | Deak-Jr | Engine | 3 | 07-19-2004 02:28 PM |
