which stock heads to get from junkyard
I got a 350 short block that im gonna just put in an old truck to use to pull my car trailer and im gonna go to the junk yard and just get some stock heads and was wondering which ones I should try and get should I just get some regular heads or get some tbi 350 heads I figured them would be a little better then the old smog heads and please dont say vortecs cause I rarely ever see them at a junk yard and if I do ill get them for something else anyhow
I have only seen vortec heads at the junkyards I go once and they were cracked and if I did find them I would get them but not for this truck I would save them for a performance build im just wanting something cheap and decent to pull my car trailer
Swirl ports should work pretty decent for what you're doing, just be sure to snag the correct intake with them,
The next most desirable cylinder head after the vortecs is the head that came on 350cid "L-98" TPI motors in 80's camaro,firebird and corvette.
They have 64cc chambers 1.94x 1.50 valves, centerbolt covers and full size ports. These are not the swirl port heads. The 4 center intake bolts are at a unique angle. The casting number ends in #083 or #217 There is a #128 and #113 corvette version in aluminum with 58cc chambers Next is the #4416 305 HO head. 58cc chambers 1.84-1.50 valve full size ports conventional valve covers and intake bolt pattern. Of course any of the late 69 up camel backs with accessory bolt holes #492 186 370 040 041 414 etc |
for a truck... that does a lot of towing... the swirl ports are fine, just be aware that their are small (~58cc) and large chamber(~64cc) chamber versions and if in doubt for something that will see heavy use lower compression will likely make you happier (I still tend to pick higher compression numbers than most and put a lot of effort into detonation control, I'd rather do extra work and get the extra MPG from the higher compression in most cases, but again, you're going to be unhappy if you end up with something that will only deal with a heavy load well on premium).
I have no idea what redeeming quality the 350 TPI heads have, I have at least 2 L98's sitting around and I doubt that I'll ever reuse the heads on them, they're just basically average smog era heads. OTOH, the 416's (used on 80's pre centerbolt performance engines like the L69, LU5 and LB9) and the 602's used on some 80s' 305 trucks and other things are actually probably my favorite traditional style production SBC heads, as long as what I'm building can deal with the small chambers (58 for the 416's, 52 for the 602's, though they both end up between 58-60cc after installing larger valves and some porting). For the most part, smaller ports, valves, chambers... will make better bottom end and MPG, and the only one that will get you into trouble on a 350 will be if the chambers end up too small/compression too high. Bigger, better flowing stuff will make more power up top but is probably not what you're looking for. Either way, I'd try to go spread bore 4bb if you're going carb... small primaries = good mpg and responsiveness down low, better than a 2bbl or a square bore, and the larger secondaries give you plenty of flow to make power up top if you want to. |
I had a set of 3947040 heads on a '68 327 4-bbl. engine from an Impala. No accessory holes and no double hump. They had a kind of right angle identifier on the ends. 1.94" x 1.5", pressed studs.
I thought the L98 heads had 58cc chambers. the use of these heads would be fine if you can find some. But as mentioned, if your just looking for low end pulling power the swirl ports will work fine.
| thumpr with stock heads? | phanline6.6 | Engine | 17 | 01-02-2010 07:56 PM |
| Stock 350 heads | 75GMCman | Engine | 4 | 11-14-2008 09:48 AM |
| How much power can I expect from stock 305 Vortec heads produce? | Lil Big Mec | Engine | 3 | 03-07-2007 08:50 PM |
| Building a BB Chevy. I want 500HP | tommytempest | Engine | 39 | 03-06-2007 06:48 PM |
| Stock eliminator | 78 monte | Engine | 5 | 01-02-2003 05:10 AM |
