Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - stock HEI to Small body HEI now there's problems, need help Doc
Old 07-12-2006, 02:47 AM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
Doc here,
Pull the module and have it checked several times..be sure it's warm during test..
Sounds like the module is going thermal .. a very common problem..
If you need a new one, have it tested the same way before you leave..and installing either make sure you use the heat sink grease..of you'll be doing it again real soon!
Doc
