Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - stock HEI to Small body HEI now there's problems, need help Doc
Old 07-12-2006, 10:41 PM
fat50chevy's Avatar
fat50chevy fat50chevy is offline
New Member
Thanks Doc, I did'nt get to pull the dizzy today to check the module but will try tomorrow before work. I did check the coil primary and sec. while hot same results 00.7 and 11.5. also checked the charging system at around 2500 RPM a pretty steady 14.45 to 14.50 . That was taking the readings from the coil + to a known engine ground. I will also try the wire from batt to coil + , but I am sure it is wired correctly and no temp relays in the system. I do have a fan installed but its manual sw no relays. I thought of that today while checking the charging system and turned it on to see if it had any effect. When I first turned on the fan it dropped to about 14.10 then went back up to 14.45 and engine did not stall during that time. I will let you know on the module,, Thanks
