Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - stock HEI to Small body HEI now there's problems, need help Doc
Old 07-13-2006, 03:19 PM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
Doc here,
If the module was not damaged in thermal cycles, It should hang in there.. If not you have a new spare.
One thing those testers can't add, is the added temp of the oil and engine heat transferring up the Dizzy shaft..(as high as 250 degrees..or the heat of the oil pump) They can only add the heat of the electrical load.
Keeps updated!
Doc
