Stock lifters-pros & cons - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2006, 07:20 AM
I have a 350 vortec engine and want to change the stock cam with one from Comp. I would like to save a little money and not change the stock lifters. What are the pros and cons of keeping the stock roller lifters?
Old 03-02-2006, 07:23 AM
MI2600's Avatar
Member# 3287
Unless your cam is a roller, that's a definite no-no. You'll wipe out the new cam.
Old 03-02-2006, 09:15 AM
Yes,the original cam is a roller cam and lifters. It is a '98 chevy truck engine which had an original roller cam.
Old 03-02-2006, 10:23 AM
engineczar's Avatar
In my opinion the stock GM hyd roller lifters are pretty darn good. Unless there's some sort of unusual wear on the bodies or they've got like 100k miles on them then I'd say it would be ok to reuse them. I'd keep them in the order in which you remove them, not so much because of how the faces wear but more how they fit the lifter bores.
If I was doing the motor for a customer I'd change them just for the peace of mind thing but for personal use it might be worth a shot.
Competition Products has OEM roller lifters for Like $150 and you might pull them out and decide they look too far gone, kind of a personal choice.
Old 03-02-2006, 06:24 PM
Vortech 4.3's Avatar
jack of all trades
the stock rollers are pretty darn good. if all looks good, use em. i am
Big Block vs Small Block Chevy bigjoedo Engine 82 05-03-2010 03:36 PM
Pro's and Con's of Positraction? Malibu73 Transmission - Rearend 54 06-04-2005 08:22 PM
pros vs cons puttung ford motor in 38 ford 38harry Engine 5 08-30-2004 05:28 PM
HELP!!! New lifters lost preload??? jonathanks Engine 3 02-16-2004 11:07 AM
350 chevy: stock cam or 3 quarter cam ? 65roln Engine 8 03-19-2002 11:18 AM
