Stock Mustang II Lower control arms on a '56 f100.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2011, 08:11 PM
Hwyhogg's Avatar
Last wiki edit: Electrolytic rust removal
Last journal entry: power tour
Hi all,
Just a post to share about my '56 Ford Panel truck suspension. It has a Fatman Fabrications, (good company to me btw), weld in cross member, shock hats and gussets. I used the stock upper and lower control arms and the strut rod. I used 11" Granada rotors. The outer tip ~1/8 to 1/4" was scraping a grove into my rotor. This was just from many pushings in and out of garage to work on. Not a big deal, took about 5 minutes per side with the 4" angle grinder. Most probably use the after market arms without the strut rods anyway, but in case you plan on using stock style lower arms, this might be an issue. No big revelations, but was something I didn't know beforehand...I included a couple of pics of the area marked with a white pencil...hope someone finds it useful BTW, the last pic is AFTER the grinding.
Name:	Dec 1, 2011 001.JPG
ID:	60388   Click image for larger version
Name:	Dec 1, 2011 002.JPG
ID:	60389   Click image for larger version
Name:	Dec 1, 2011 008.JPG
Old 12-02-2011, 08:13 AM
Congrats
Let's keep the good work up. I am currently working on a 54 Ford P/U, using a stock Mustang II setup (actually a 73 Mercury Bobcat). Will be posting photos shortly. Hope to get a lot of advise from you and others
Old 12-03-2011, 02:21 PM
Hwyhogg's Avatar
Thanks and welcome aboard. I have pretty much been learning as I go with this project and have gotten invaluable information from the guys on this site! Feel free to look at my project journal. I post the good, bad and the ugly. I'm not trying to reinvent the wheel, so I'm always open to comments, suggestions and concerns. Good luck on your project..you've found a great place to learn and share your own experiences!
James
Old 12-12-2011, 03:44 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Think long and hard before installing strut-rod eliminator A-arms. Aftermarket suspensions have a bad history of failure using these. Unless you have a fenderless rod that will only be drive th Sonic Drive-in on Friday nights, keep the strut rods. And even using those, be sure the back mount is very strong. One of my favorite pass-times is pointing out cracked welds on brackets to rod owners at rod runs.
Old 12-12-2011, 07:27 PM
Hwyhogg's Avatar
Thanks Willys. Always looking/listening for others' experiences. I will keep a close eye on those welds; especially since I didn't weld them.
Old 12-12-2011, 08:07 PM
Wiki Edits: 27
good tip.
This is the first time I have heard about the interference , Most M II get gm or mopar rotors, This winter My son wants to finally get the M II under his 36 PLY. He said he is going to use the stock MII crosmember and granada - Versailles rotors-calipers since we have them up in the parts rack. It already has a lincoln TC 8.8 disc rear.
Old 12-13-2011, 10:55 AM
Wiki Edits: 21
I like his plan! I trust Pford engineers over all the after-market suppliers. I highly recommend he also use the factory strut rod mounts and BOLT them to the frame as shown here and pictures below.
Old 12-20-2011, 04:36 PM
56 F-100
Just started on a 56 F-100...it has a Mustang II IFS...what are you going to use for a motor? I'm planning on a SBF 302/351...working on engine mounts now.
Old 12-21-2011, 09:25 PM
Wiki Edits: 27
Mustang strut rods,
Mustang II' s were different than Pinto's, Mustangs had the rubber biscuit mounts, more bracing from the floor to the bottom of the instrument panel and more sound deadners in the body structure. The push was on for NVH reduction. ( Noise, Vibrations, harshness). In the factory the steering rack nuts were crimped by a big heavy combination torque control driver-crimper.the Mustang suspension moved around more than pinto's because of all the rubber mounting. I heard that the nuts loosened on some of the first prototype during the 50 K durability runs. I always locktite suspension fasteners. I never did see the factory repair standards info on the suspensions.
Old 12-22-2011, 06:35 AM
Ifit aint fix...Don't broke it
Last journal entry: I am ALIVE! 65GTO FRAME OFF
strut rods
I had the same problem, I ordered several different ones untill i got the fatman brand fir 99 bucks online. These were nice and snarfy with big heavy plates to notch and weld. pictures on my journaj pages
LOWER CONTROL ARMS. PLEASE HELP Pro1972nova Suspension - Brakes - Steering 4 03-01-2012 10:19 PM
Lower Control Arms globb Suspension - Brakes - Steering 1 05-28-2011 02:28 PM
lower control arms runn141 Suspension - Brakes - Steering 5 05-02-2007 05:49 PM
56 Chevy Lower Control Arms Brian's56Chevy Suspension - Brakes - Steering 4 08-23-2006 07:56 AM
Nova Lower Control Arms Pro1972nova Suspension - Brakes - Steering 1 12-15-2002 02:26 PM
