Stock pushrods? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2011, 06:52 PM
Stock pushrods?
Will my stock pushrods work with a howards cam with 1700-5700 rpm 284 intake/exhaust duration, .470 intake/exhaust valve lift
Old 09-15-2011, 07:06 PM
DoubleVision's Avatar
They`ll work, but inspect them very carefully. Check them for straightness and make sure the passages are clear. Also check both ends for wear. It`s recommended to go to heat treated push rods anytime the cam is stepped up, but when I was starting out I ran a cam larger than yours on stock pushrods and didn`t have any issues.
Old 09-15-2011, 07:07 PM
thanks for your help
Old 09-15-2011, 07:16 PM
Wiki Edits: 49
Need to qualify that.... Depends on the engine.
For a SBC, Doublevision is correct.... BUT that may not be the correct answer for other engines.
I have no doubt you're probably working on a SBC...... BUT when asking a question please provide more info so you can get accurate answers. We can't read your mind so we don't know if you're working on a Mopar, Ford, AMC, Buick, Olds... whatever and not all engines are designed the same so the correct answer for one engine may not be the correct answer for another.
Just food for thought.
Centerline
HotRodsAndHemis.com
"Instructions are just the manufacturers opinion of how it should be put together". - Tim Allen
pushrods and cam? Linez35 Engine 6 09-03-2011 05:39 PM
New Pushrods... Guy Hiltz Hotrodders' Lounge 10 01-09-2011 02:36 PM
Pushrods rub awoodman Engine 11 11-11-2007 11:02 AM
Pushrods 73fj55 Hotrodding Basics 1 01-19-2006 06:36 PM
pushrods joes350truck1 Engine 1 04-07-2003 07:32 PM
