Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Stock SBC 350 Crate Motor valve chatter under load
  #30 (permalink)
Old 02-26-2013, 08:08 AM
Northern Chevy Northern Chevy is offline
I forgot to add, if you did decide to change out the cam shaft, make sure your distributor gear and shaft play are good so there would be no chance of eating the gears off of both as its easily overlooked. At least a normal grade cast dist gear is very cheep to purchase if needed. I expect $300.00 would cover the cam kit, all gaskets for the timing cover and oil pan and dist gear if needed.
