Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Stock SBC 350 Crate Motor valve chatter under load
  #45 (permalink)
Old 03-04-2013, 11:32 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Originally Posted by spinn View Post
I think the cam can be advanced 6 by using the dot to A on the timing chain gear set. He could have checked that visually at tdc.
This is supposed to be a GM 350-290hp crate motor. It should not have a multi key crank gear on it.
Never assume the multi key crank gears actually will move the cam accurately,
by the desired amount. (they don't)
You want to move the cam accurately by first determining its real installed position first. By degreeing it.
