Stock SBC 350 Crate Motor valve chatter under load - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 03-07-2013, 01:18 PM
I wonder if the sludge was that bad that it held the oil back from flowing out of the heads { assuming you meant sludge on top of the heads } that it helped promote the PCV to suck up oil .. its only a thought. Do you know the past history in how often the engine oil was changed and what brand of oil was used and what I am driving at there is the fact the oil wasn't doing a very good job at keeping the sludge at bay or somewhere along the line the PCV valve plugged up, a thermostat not keeping the engine up to temperature etc. I realize the humidity factor of your area could be an issue in keeping an engine cleared out of moisture but can't be worse then the south eastern states or for that matter up here in the winter.
I just know with my own 1995 350ci, in sorting out my own engine miss issues I had the valve covers off and I was surprised to see how clean it was, just a slight discoloration film on the rocker arms and the head surfaces were spotless and only a thin layer of build up in the very front end of each valve cover. I have used 0W-30 synthetic all along from Imperial .. now Mobil and change it every 3000 miles and the engine has 186000 miles on it. Hard to say if it would have looked the same with another oil as I have nothing to compare with.
It may not hurt assuming the combustion chamber cleaning products work, to run some through on a regular basis and hopefully keep the carbon build up down. At least as time goes on you can pop the valve covers off and see how the top side of the heads look.
  #47 (permalink)
Old 03-07-2013, 04:43 PM
The sludge and oil was actually on the cumbustion chamber side along with the inside of the head. I have no doubt that it was effecting the way the valves worked. There was a lot of oil getting sucked into the intake.
  #48 (permalink)
Old 03-07-2013, 05:43 PM
Oh I get you now, I just associate sludge with the topside of heads, lifter valley and oil pan. So where it came from, ether the PCV valve and may or may not mean excessive ring blow by or you also had intake gaskets leaking from underneath, this is assuming your valve guide seals really are good .. hope so after having the heads checked out!. I would think you would have been going through a certain amount of oil, consumption wise then in the last while.
  #49 (permalink)
Old 05-23-2013, 06:15 PM
B.A.M.F
glad it all worked out for you.
Acceptable flywheel runout for 350 sbc..clutch chatter.. F&J Transmission - Rearend 13 04-08-2012 12:08 PM
350 light valve rattle under no load Aerotech Engine 14 11-10-2009 09:45 PM
What should initial timing be on a 94 350 sbc crate motor? batman09 Engine 4 09-14-2004 07:32 PM
Stock crate 350 (Cam Questions) Savage64chevy Engine 3 01-21-2003 01:34 PM
350 sbc crate motor questions bentwings Engine 7 10-29-2002 09:03 PM
