-   -   Stock SBC pushrod length? (http://www.hotrodders.com/forum/stock-sbc-pushrod-length-216809.html)
chucksrt 03-16-2012 03:51 PM
1 Attachment(s)
I am trying to figure out how long the stock pushrod is because when I measured to check what length I need it looks a hair taller than stock. I measured my pushrod to be 7.200" (length checker is 6.800" and I had to turn it out 8 full turns, each turn is .050"). The stock pushrod is only a little shorter so it's not a complete turn or .050 shorter.
I attached a pic of the valve stem tip wear pattern, does it look ok? Thanks, Chuck
chucksrt 03-16-2012 05:17 PM
Called Summit and they said that the stock length is 7.195"
Richiehd 03-17-2012 05:31 AM
If its a Small Block Chevy, stock length is 7.800.
and the pattern looks good
garrell.770 03-17-2012 06:30 AM
I still struggle with my memory problem but there use to be a method of measuring to get the correct pushrod length, can't it vary with rocker arm ratio, cam specs etc. Do you know the engine is stock from Gm?
I know I didn't help any, just mainly thinking out loud.
Garrell
chucksrt 03-17-2012 07:03 AM
I built a 383 for my conversion van. It is a 96 Chevy Express 1500 with the Vortec engine. Summit said that stock pushrods for this engine are 7.195" long. I am using Edelbrock E-Tec aluminum heads and their site says thet I would require .100 longer pushrods with these heads (but they also say the pushrods are 7.800" long too). My engine uses a roller cam and lifters so I figure the pushrods are shorter due to this. I originally bought aluminum full roller rocker arms and with them I needed a much shorter pushrod-6.800" but once installed they were hitting the valve covers so I swapped to a set of steel rockers with a self aligning roller tip and now I am finding that I need a 7.200" pushrod. So I ordered them yesterday and I will hopefully have them by Monday. I just want to be done with this build! I have had soooo many issues while building (went through 2 blocks and 3 sets of heads), then I got the engine shoe horned into the Van and I then found I had more issues and went through (2 sets of lifters and 3 sets of rockers) So I would really love this to be done soon!
garrell.770 03-17-2012 11:51 AM
stock sbc
I had 1:8 to 1 full roller tip rockers and bee hive springs installed in my 6-0 LQ9 landspeed race truck two weeks ago, I also put 3/8" heavy wall pushrods in and they had to be a different length than original. The performance shop that did the work explained how to determine the correct length but I can't remember the method.
Garrell
SSedan64 03-17-2012 12:08 PM
Length depends on parts used. Search for Valvetrain Geometry or Mid Lift & you should find what you need to figure correct length.
Stock Pushrod Lengths:
Flat Tappet = 7.794"
OEM Roller = 7.195"
Retro Roller = 7.290"
chucksrt 03-17-2012 01:24 PM
I have been reading all sorts of pages on this. I found that the wear pattern should be no bigger than .060-.080 wide on the tip of the valve. I haven't measured mine yet , it looks centered but I keep hearing to have a narrow pattern. I want to triple check the mark just to be safe.
Richiehd 03-19-2012 05:51 AM
Sorry, you didn't say it was a roller, I assummed, my bad.
Pattern looks good, shortest pattern, in the center of the valve.
