Stock vortec head more lift - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2009, 07:47 PM
I see the most popular way is to use behave springs But after searching they are spring and retainer seal packages that will alow greater lift.If the lift stays at or below .500 and its not going to see much over 5000 rpm .Will the behive have any advantages over a conventional stye springs
Old 02-09-2009, 03:58 AM
SSedan64's Avatar
No..........
Old 02-09-2009, 10:12 AM
If the engine won't see much over 5000 RPM, why are your going the route of .5 inch lift. This simply isn't compatible with the stated use.
This gets to sound like an over cammed engine which is miserable to live with in the lower RPM ranges where it sounds like it will spend most of its time.
Bogie
Old 02-09-2009, 01:56 PM
cool rockin daddy's Avatar
David,
You really seem confused by the nature of your posts concerning the vortecs. What do you want this engine to do? How are you going to drive the car? Bogie is right, you are heading towards overcamming this engine. You have read the Goodwrench Quest article, yes? Is there anything else you require power-wise than what this engine provides? Beehives are probably overkill but they don't require machining the heads. If you look at a site like Scoggin Dickey, they sell modified vortecs with new springs that can provide up to .550 lift. A much better deal than Patriot heads in my opinion. You HAVE to decide what this engine is for before you can go any further.
Old 02-09-2009, 02:51 PM
Banned
this cam with 1.6:1 rockers would put you a hair over .500" lift and work just fine up to 5,000 RPM. And its not even roller stuff. there are others like it but this is just an example of why it may be desireable to run beehives on an engine that normally will not go over 5,000 RPM.
http://store.summitracing.com/partde...4&autoview=sku
Old 02-09-2009, 08:15 PM
Re behives
Sorry guy somtimes I get in a hurry.I,m not going .500 lift on this engine.Goodwrench with Vortec heads.(used need to go to the machine shop)I thinkI.m going with the Comp 268 or the or 262 Extreme which ever will work better wish I could see some power curb charts to get a better feel for I want. I,m trying to get a feel for the best way to get the lift out of the heads according to what i,ve read the stock springs won,t safely do either one of these cams using a .050 manrgin I think? I asked about the the behives because it it mentioned as a drop in method.My buddy found other springs and retainer combo that will work for cheaper.I see that behives can add power but I think it would be at hi rpms and big lift.Now if I get a good running head combo I may put it on a slightly more high revving engine is why I mentioned .500.But also I guess I could change springs any time.
Old 02-09-2009, 10:57 PM
SSedan64's Avatar
Check out Comp's Cam Quest6 free download program. You can Dyno their cams.> http://compcams.com/camquest/default.asp
America's Pride Lift Ampro, whole sad story [long] kgus Garage - Tools 106 04-13-2009 05:59 AM
What will I need to do to my Vortec heads to accept this kind of lift? 04SilveradoMykk Engine 13 07-25-2008 02:59 PM
Valve Stem Angles, Do they Matter? Truth or Fiction? QuenchPiston Engine 35 12-28-2006 10:11 AM
NEW GMPP VORTEC heads !! terror385 Engine 1 07-11-2004 09:48 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
