Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - STOCK VS ROLLER ROCKER ARMS??????
Old 06-17-2002, 08:07 PM
jimm jimm is offline
gonzalez,howdy! if you go with the 1.6 ratio you will increase your valve lift [a little heavier breathing/exhaling] however i suggest going with full roller rockers as opposed to only roller tip.crane has a budget line of full rollers [blue racer line i think] they go for about 160.00 around here. the valve covers have to be taller because of the poly locks on the rollers.the full rollers are pivoting on bearings as opposed to one hardened steel ball.the rollertips only have a roller at the tip. you shouldnt have to make any changes to install an appropiate set of full rollers on your 350 other than possibly your valve covers and i have installe an additional cork gasket on my covers and put them back on ,hope this helps, see ya!,jimm
