stock vw transaxle - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2006, 06:48 PM
camino_man's Avatar
go like he11 machine
stock vw transaxle
hey guys, well i just put my el camino with the mild sbc 400 up for sale but im going to build a 60-72 beetle for street/strip. i was wondering how much the stock transaxle can take before a professional built one or modified one would be needed? also what is a good forum to go to about vw's? thanks
Last edited by M&M CUSTOM; 04-27-2006 at 08:06 PM. Reason: Selling stuff on the forums is forbidden, put it in the classifieds.
Old 04-27-2006, 07:09 PM
I'm currently rebuilding my sandrail. This time around its getting a turbo and a programmable efi system, and i also replaced the stocksheet metal in the rear engine mounts with DOM.
The stock trans will not hold up very well with any engine mods. There are a few options, a porshe trans is almost a direct bolt in and has 5 speeds, they can be had on ebay for around $100. Aftermarket transmissions built for racing are very expensive $5000.
You are definatly going to bust the 1st gear real quick especially drag racing. You could also buy a aftermarket diff with 4 spider gears for around $100. Or weld the hubs.
Basically the stock trans isn't very good.
try www.cbperformance.com for trans parts and www.chirco.com
Brendan
Old 04-27-2006, 07:30 PM
camino_man's Avatar
thanks, ive found several long block assemblies on ebay from a manufacturer of them for about 2 grand for 180-220hp engines. i think im going to go with the 180hp version. do you know what kink of e.t. a bug could run making this kind of hp? i know theres a lot of other factors like tire size, and gear ratios but just a rough estimate? what kind of porshe trans will work?
Old 04-28-2006, 05:26 PM
I'm not sure about ET's because i haven't drag raced mine, but before the turbo and efi it would wheelie inbetween shifts. The trans from a porsche 901,911 i think will work, just look for one and it looks very similar to the VW trans, the engines also look very the same
Brendan
after market or stock rods? jesse01 Engine 10 03-12-2005 07:04 PM
Stock rod bolt ? bowtieorbust Engine 1 11-09-2004 01:08 PM
stock vs. aftermarket intake darom Engine 13 11-03-2004 08:35 PM
sleeper cars antirice Hotrodders' Lounge 25 08-01-2004 09:29 AM
400 Compression, Stock Pistons Deak-Jr Engine 3 07-19-2004 03:28 PM
