stoker oil pan question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2007, 03:07 PM
i am putting a stoker kit a 350 4 bolt main....gen 1 and i need to know if i can use a stock oil pan or if i have to get a deeper one....some of the ones on summit said...("stroker oil pan clearance"....no) sooo thats what got me thinking that i may need a new oil pan..is this true??.....also....with this 383 what kind of carb should i put on their...people are telling me something over 700 with vac secondaries...what about dual 500's....or even something smaller in duals???? would duals give me more power or just flood my engine with gas???
Old 02-22-2007, 03:21 PM
SSon18s's Avatar
Your oil pan clearance depends alot on the stroker kit you put in your engine. I used a stock oil in my 383 build up. I also used a Holley hp seres 750 with manual secondaries. I have dart iron eagle platinum heads with 230cc runners also so my motor breathes a little. It all depends on you engine
Old 02-22-2007, 03:34 PM
327NUT's Avatar
You don't need a "stroker" oil pan, I've built 2 383's with stock pans....but also used stock rods, never hurts to check for clearences though when you get ready to button it up. The carb choice has been discussed numerous times here, just like camshaft choice. Like said previously it depends on several things...intended use and the overall parts combo of your engine. If its mainly a street driven veh. then I would stay with a 600-700 vac. sec. Holley or Edelbrock, don't leave out a GOOD rebuilt quadrajet either. I personally would'nt use a dual quad setup unless you just had to have the look, but if you do keep the carbs at 500 cfm or less. Good luck with your build and do a search for "engine break in oil", lots of good info there
Old 02-22-2007, 03:44 PM
are you sure??? ive been reading that some people have problems with pan clearance...and since i just have the block i wouldn't want to buy a stock oil pan and have it hit in places...
Old 02-22-2007, 04:00 PM
327NUT's Avatar
Like I said I used stock prepped rods with ARP rod bolts, did'nt have a problem. If you use cap screw type rods then you need to check clearences on your pan, block and cam. Its all part of building a stroker or any engine for that matter, "gotta check things." And you'll find that some guys just have to have that deep sump or kick out pan, looks racy!!!!
Wich oil pan you use on your 383 stroker? TVR383 Engine 10 01-30-2007 08:21 PM
oil leak rb8179 Engine 11 06-03-2006 04:07 AM
Oil question! Ratoflic Engine 17 02-09-2005 12:23 PM
Front oil pan seal on Small Block Chevys gearhead77 Engine 19 09-26-2004 09:58 PM
Oil Pan/ Windage Screen Problems DTL504 Engine 4 05-13-2004 05:37 PM
