Stop Interior noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2009, 12:58 PM
Stop Interior noise
Hi ,I'd like to know if anyone has ever used Spectrum on the outside of the floor pan .Did it quiet down your ride?,Thanks,Bob
Old 08-30-2009, 04:13 PM
I used DynaMat and Lizard Skin.
It seems to cut out a LOT of the heat and noise.
Old 08-30-2009, 04:29 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
This wiki article may be helpful to you: Ceramic insulation.
We also have a designated Sound deadening article. However, it's not very well-developed yet. If anyone can add to it, please do so. Thanks.
Old 08-30-2009, 09:21 PM
jmfalco's Avatar
Last journal entry: Original wood for Drip pan
I would think anything on the outside (underside) of the floor pan would soon go away if not protected. I am going to install mine on the top side (inside) of the floor pan.
Jack.
Olds silhouette 4t60e periodic no downshift at stop Mad_Max Transmission - Rearend 1 07-26-2009 10:52 PM
350 bog from a stop..edelbrock parts. need HeLP spacechimp Engine 18 07-14-2009 12:51 PM
Do I need a stop for my hyd clutch? Mike Britton Transmission - Rearend 5 11-13-2006 07:25 AM
IFS dead stop iceman36 Suspension - Brakes - Steering 2 05-05-2006 01:42 PM
Bad Stop light?(brake light) A-BodyFan Electrical 7 03-09-2006 03:19 PM
