Stop light and turn signal problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2008, 06:42 PM
dac dac is offline
Just bought a hot rod. 34 ply 4 dr sedan on a tube chassis. Mustang front end. SBC 350/350 to 10 bolt chevy rearend. All the lights worked when purchased.
Question. The taillights work on both sides. The left rear stop light works but not the right. The left turn signal works but the right. There is a brake light pressure switch in the rear brake line. There are two wires connected to it. Does this switch act as a circuit breaker and both lights should come on when activated or do each of these wires control the lights independently. I reversed the wires at the switch and the results are exactly the same which indicates to me that this is not the case. I KNOW.....why don't I just replace the switch and see.
If you could see where it is YOU would know why. I have about 10 puncture wounds on my right hand from reversing the wires.
Old 10-30-2008, 07:02 PM
302 Z28's Avatar
The pressure switch is just a switch, one wire going to it should be hot. When the switch makes contact both rear brake lamps should go on. You can connect both wires from the switch together and that should make your brake lights come on. First off make sure all your bulbs are good. Do not assume since they are new that they are functioning properly. Visually inspect the filaments of all of them and make sure no filaments are crossed. Another area of problems is the turn signal switch.
Vince
Old 10-30-2008, 08:14 PM
Cape Cod Bob's Avatar
The pressure switch is working because the left light works. The [poweer is not flowing thru the right bulb. Could be a bad ground at the housing. Get a tester and see if the power is getting to the socket. If it is make sure it gets to the bulb and to ground. If no power to the socket then be sure it is getting out of the column. Most likly a bad ground ,loose wire , bad bulb. Try switching them
Bonneville Tail Light and Turn Signal Problem darksider Electrical 3 01-09-2008 01:30 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
brake light, turn signal, tail lamp problem worknprogress72 Electrical 6 01-06-2006 12:20 AM
How many rodders does it take to change a light bulb? Dusty82 Hotrodders' Lounge 6 09-01-2005 10:02 PM
turn signal and brake light problem PrimeMover Electrical 5 05-27-2003 06:26 PM
