Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Storage Tank for Air Compressor?
Old 01-30-2010, 08:14 AM
matt167 matt167 is offline
Wiki Edits: 31
with that setup, you will not need extra air... the reason they sell such a thing is most for larger equipment... the only benefit you would get out of a storage tank, would be colder air, but being the compressor you bought has a drier ontop of it ( which is an air conditioning unit basicly ) I doubt you will have a problem.. not to mention, it would take your compressor double the time to pump up after you drain the tanks.. you would benefit more with a second drier setup if you were worried about the air temp
