Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Store made spray paint
  #22 (permalink)
Old 07-11-2012, 10:42 PM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
Originally Posted by kaw550 View Post
Here are a couple of pictures. There are a couple of small bubbles at 12:00 and a larger section at 3:00 (that extends under the gray plastic trim)
I posted before The pics showed up,sorry...
Kaw ,That aint so bad and your on the right track dont worry about blending the paint....pinstripe it and get some chroma base or some other good paint if you can afford it (better color match) If not,Omini PLUS (PPG) is pretty good with a match and its about 30-40.00 a quart for silver(waaaaay cheaper than chroma base)... maybe a pint of paint and some reducer .and a quart of clear maybe some omini Quick clear with a fast hardner at 50.00 (drys fast ,less trash) if you've painted before and have a gun you must have a compressor so your way ahead of a first timer that thinks everything is easy and we just rip people off ...
I use Oshho to remove rust its much better than rust mort and costs about 15-20.00 a quart and you wont even use an 1/8th of of it...
